"Rocked" chain repair
Discussion in 'Chainsaws and Power Equipment' started by JW IN VA, Jan 1, 2021.
  1. JW IN VA
    JW IN VA
    Virginia mountains
    Has anyone else tried taking a raker file to cut the shiny part of rocked teeth back then sharpened as usual.
    I tried this method on my last mistake and seemed to work well. A lot less time than filing back with a round file.
    Other experience welcome.
  2. JimBear
    JimBear
    That is was my preferred method before I had a grinder. I used a flat file & eyeballed the witness mark and took the tooth back until it was cleaned up. I would use a magic marker on the edge so I had a little visual help making sure I didn’t leave a small flat on the cutting edge when sharpening. I still use the flat file if the teeth are really goobered up.
  3. Mag Craft
    Mag Craft
    South East Wyoming
    I always grind chains that have been rocked.
  4. buZZsaw BRAD
    I have not but recently learned of nicked teeth on the drive links when a chain is thrown.
  5. buZZsaw BRAD
    Just so i fully understand, what exactly is a rocked chain?
  6. Nixon
    Nixon
    West Sunbury,Pa .
    When you hit a rock ,dirt ,nails , etc.. with your saw ,and really mangle the cutters . You can also approximate a rocked chain running it dull for a log time .
  7. buZZsaw BRAD
    QUOTE="Nixon, post: 1209095, member: 74"]When you hit a rock ,dirt ,nails , etc.. with your saw ,and really mangle the cutters . You can also approximate a rocked chain running it dull for a log time .[/QUOTE]
    Thanks :handshake: More of less what i was thinking.
  8. Mag Craft
    Mag Craft
    South East Wyoming
    If you happen to hit a rock by accident or because you hit dirt by accident or a rock embedded in the wood the corner of the cutter can be bent. So usually the cutter has to be ground back or filed back far enough to eliminate that bent portion to make it cut correctly again.
  9. The Wood Wolverine
    If I have a really badly rocked chain, it’s quicker for me to use a round file to remove damage, then go back to square. A good sharp round file will remove material rather quickly with a decent amount of pressure.
