Right in the middle of plowing
Discussion in 'Chainsaws and Power Equipment' started by papadave, Dec 19, 2016.
  1. papadave
    The Cub wouldn't restart. This was a few days ago.
    I took a short vid of trying to start, and the ensuing groan......
    Bad starter?
    colin.p and savemoney like this.
  2. Canadian border VT
    sounds like the bendix isn't going far enough... if it was really cold put it on a battery charger.. it works on my old cub...
    colin.p, savemoney, Horkn and 2 others like this.
  3. papadave
    Thing is, it was working just a couple minutes prior, but yeah, it was cold.
    I can put it on the charger too.
    Horkn and Eric VW like this.
  4. jo191145
    jo191145
    Ct
    When you get it running see if it smokes like crazy. You wouldn't miss it tho.
    My sit down does that even in the summer. Gas runs through the carb while sitting, fills the cylinder drastically increasing compression until the exhaust valve opens and dumps it all into the muffler.
    My lazy man fix was putting a fuel shutoff on it. Works as long as I and everyone else who uses it remembers.
    Ethanol
  5. J. Dirt
    J. Dirt
    I'd vote for starter bendix not spinning up high enough to grab the ring gear teeth. Could be dirty, worn etc. worst case the teeth are blown off it or a spot missing teeth on the flywheel ring gear, but I would check the starter bendix first. Try turning the flywheel a touch by hand then hit the starter see if she grabs
    colin.p, savemoney, Horkn and 3 others like this.
  6. J. Dirt
    J. Dirt
    Pesky little carb shut off on the bottom of the carb? My dad had fought the same problem all last summer then went and got a new mower and the old one is now in my barn to add to the future project list
    colin.p, Horkn and Eric VW like this.
  7. Boomstick
    Boomstick Banned
    Saratoga county ny
    Ditto!
  8. Canadian border VT
    Horkn, Eric VW and papadave like this.
  9. J. Dirt
    J. Dirt
    Have to admit every time I see your handle "Boomstick" I chuckle a little cause that's what my brother and I have referred to our slug guns as since we started deer hunting with them :rofl: :lol::thumbs:
    savemoney, Horkn and Eric VW like this.
  10. papadave
    Unfortunately, I've been too busy, but I plan to get out tomorrow and check it out.
    Won't matter much, as we'll be out of town for a few days (nephew watching the house and dogs for us) for Christmas.
    Stinny, savemoney, Horkn and 4 others like this.
  11. J. Dirt
    J. Dirt
    Put him to work on the Ol cub while he's there :D
    savemoney, Horkn, Eric VW and 2 others like this.
  12. papadave
    Hmmmmm......nope.
  13. J. Dirt
    J. Dirt
  14. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Yup sounds like the starter. The genius who thought up the plastic gear on a spring to grab a cast flywheel was off his rocker.
  15. Eric VW
    Nephew gonna be to busy throwin a party?:whistle:
    savemoney, Horkn and papadave like this.
  16. HDRock
    WD 40 :D
    colin.p, Horkn, papadave and 2 others like this.
  17. J. Dirt
    J. Dirt
    Man if I was your nephew I'd gladly fix the tractor then play in your stacks and fire your stove:D
  18. Eric VW
    You're young enough to be papadave's son, let alone his nephew :D
    papadave, Horkn and J. Dirt like this.
  19. Horkn
    My MTD does the same thing. The previous owner put a shutoff in the fuel line too.
    Faulty fuel shutoff Solenoid
    Could be the real answer to Jo's problem instead of blaming ethanol.:yes:
    That doesn't sound like the answer to papdaves issue though. Although this thread may have been detoured from the way it seems.:D
  20. Horkn
    Bingo!!!
    A fuel shutoff works around the issue for cheap. It's worked flawlessly for 8 years that way. Engine off, shut fuel off. Easy peasy.
    colin.p, savemoney and J. Dirt like this.
