Rigging Rope Question
Discussion in 'The Wood Pile' started by Ralphie Boy, Dec 31, 2017.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I'm looking to buy 150' of rigging rope. I don't plan any real heavy or technical work so I'm thinking 1/2" with about 7000 lb tensile strength. What do you think and what brand would you recommend?
    :salute:
    Wasn't sure whete to post this.:confused:
    blacksmith and Breechlock1 like this.
  2. bogydave
    Nylon seems to last a long time
    Not sure if 7000 lb rated though
    Breechlock1 and Mag Craft like this.
  3. bogydave
  4. Breechlock1
    Breechlock1
    What are you doing with it? Are you climbing and rigging pieces down? negative blocking? or are you just using it as a pull line?
    Scotty Overkill likes this.
  5. dingbat
    dingbat
    Western Northern Cackalaky
    I've used newengland ropes km-III for the canopy tour I ran in my past life. Kernmantle construction. Really nice hand, took knots well, held up to quite a lot of abuse. 7/16" is over 7000lbs. 1/2" is over 9000lbs.
    I gave away thousands of feet of it barely worn or not worn at all from timing out (5yrs.) for life worthy use.
    blacksmith and brenndatomu like this.
  6. mike bayerl
    mike bayerl
  7. mike bayerl
    mike bayerl
  8. Breechlock1
    Breechlock1
    mike bayerl likes this.
  9. JustWood
    JustWood Guest
  10. dingbat
    dingbat
  11. Ralphie Boy
    Ralphie Boy
    Mostly as a pull line.
  12. mike bayerl
    mike bayerl
    1/2" Samson Pro-Master 3-strand rope works great with a Maasdam rope puller.
    Ralphie Boy likes this.
  13. Breechlock1
    Breechlock1
    Get yourself a 3 strand from any of the wespurs, treestuff, Sherrilltree.
    mike bayerl and Ralphie Boy like this.
  14. Scotty Overkill
    Spend money on good rope, trust me on this one.....
    I have a lot of Yale hanks, and some Samson as well. Some 11mm, some 13mm, and some 15mm. Each for its own task.
    tamarack, blacksmith and Ralphie Boy like this.
  15. Alan Leedy
    Alan Leedy
    Charleston, WV
    NE kernmantle rope is great stuff, nice and supple. also have a lot of experience using PMI Pit rope both in 11mm for SRT in vertical caving. The new England is easier to rig but the sheath on the PMI is tough stuff.
    dingbat likes this.
  16. oldspark
    oldspark
    NW Iowa
