Reversing a Reverse: Chimney
Discussion in 'The Wood Pile' started by iowahiker, Nov 25, 2023.
  1. iowahiker
    iowahiker
    NE Iowa
    I purchased a rechargeable keyboard blower or duster (Amazon) to help start my outdoor grill which uses paper, kindling, and maple sticks and found it can also reverse my chimney when it back flows in the morning. I just point it at the interior top of the furnace, pull the trigger, and it returns the draft to up during the occasional cold morning downdraft.
    Blowing the grill mix of paper, kindling, and maple sticks produces hundreds of embers which would be messy and dangerous indoors so I NEVER blow the burning material in the furnace.
  2. MNWoodMan
    MNWoodMan
    Mankato ,MN
    I have the same problem but my stove is on a pedestal with an ash draw, so I use a store bought fire starter lots of dry kindling and a small fan. Get your stove loaded and ready to light light the fire starter and shut the door, all dampeners wide open turn the fan on high and place in the ash draw opening. Its like forced air induction works well in my set up. I struggled with this on my first year but got this to work for me. What type of stove do you have.
  3. wildwest
    Wyoming high plains
    We have to use a hair dryer to warm out exterior masonary chimney to reverse the draft when it's cold. Rolled up newspaper on an angle works when electricity is out but it takes awhile.
  4. Butcher
    Butcher
    I have found that starting a cold stove for me and my set up works best when useing the top down method. Big splits on the bottom, medium and then the paper/kindling on top. But thats just me. When its cold here I am not usually starting a cold stove or I would be cold.
  5. JimBear
    JimBear
    I like your line of thinking.
  6. brenndatomu
    WOW! A Butcher sighting!! You are on the missing members list sir! Howz things?
    Good to see ya check in again...stop by more often! :handshake:
  7. Eckie
    Eckie
    I've found that works best for me as well. The "small fire first to make coals" leads to smoke everywhere when it's time to load the working wood.
  8. Woodwidow
    yes, nice to see you here again.
  9. Va Homesteader
    Va Homesteader
    Central Va
    When faced with a cold chimney downdraft I simply open a window in the area of the stove and it solves the problem. once the fires lit and smokes going up the pipe the window is closed.
  10. Skier76
    Skier76
    CT and SoVT
    Same here. Stove on the lower level. I often crack a window and open the door when lighting a cold stove.
  11. Stoveaclaus
    Stoveaclaus
    Long Island, NY
    I bought the draw collar. I hooked it up to a wireless plug that i connect to my phone. As I leave work I turn it on and in 15 minutest the flu is heated up and is drawing perfectly. I haven't had a problem since. I would highly recommend. Cost is about $300 but well worth it IMO.
    NH mountain man, Skier76 and Eckie like this.
