Revamped my Sawbuck
Discussion in 'The DIY Room' started by Grizzly Adam, Oct 11, 2013.
  1. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    Revamped the sawbuck to match the new wood stove. Removed one of the two centre bars and move the remaining one into the middle cut the removed bars and placed them under the gouged up crossbars.
    Semipro, schlot, Gark and 3 others like this.
  2. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Looks like it's getting some good use. Where's Lakota? I'm heading out to Cedar Rapids in a couple of weeks for a wedding.
  3. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    Yeah, you sure can tell where the old sweet spot was. Lakota is about as far north as you can get and still be in Iowa, and pretty much dead centre as far as east and west go. Closer to the twin cities than to Cedar Rapids, although once the kids graduate I want to move to the country between CR and Iowa City.
  4. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    I've heard the mushrooms are very good in northern Iowa.
  5. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    I only know of one hotspot, and it's typically well picked over.
  6. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Here's my sawbuck, made out of old picnic table
    schlot likes this.
  7. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    I've either seen that or one like it, a bit short for me though, I'm 6'4"
  8. Lastmohecken
    Lastmohecken
    Arkansas
    I don't really need one, since I hardly ever end up with one too long to go in the stove, and I seem to always end up with a lot of shorts, anyway. If a full length one won't go in the stove it's because there is a lot of coals built up in the back of the stove or the wood is in there sort of slanted and high in the back, in which case I just throw a short in that I already have or split one smaller if needed.
    But this thread and pictures gave me a vision of one I would build which I think would work great. I would build a solid V- shaped top that would hold anything regardless of length, but there would be a gap of a few inches at one point where I could cut through it with the saw. All I would have to do is place the wood in the Vee with the area I want to cut over the gap and saw through it. There should be no pinching of the bar, if the wood is placed right, except maybe for the odd piece of wood, and in that case I would just roll it over and finish my cut, but if build right, I think one could do an undercut if needed. I am tempted to build one to illustrate, but I doubt I would ever use it much.
    brenndatomu likes this.
