Removing silver skin?
Discussion in 'Everything Else (off topic)' started by Marshel54, Dec 12, 2020.
  1. Marshel54
    Marshel54
    I am in the process of cutting up some deer meat my son gave me.
    It is not going well. I will pressure canning the meat. Any way to get that silver skin off or does it matter?
  2. huskihl
    huskihl
    No need if you’re canning it
  3. lukem
    I usually don't bother unless it is a really old deer.
  4. Will C
    Will C
    New York
    Sharp knife and patience!
  5. basod
    basod
    Mount Cheaha AL
    If you don’t prefer venison in raw form and are trying to make it more palatable then try to remove it- it ain’t gonna be beef
  6. XXL
    XXL
    Ontario, Canada
    I have never canned venison but I like to remove it from my cuts. I use a thin knife, like a boning or fillet knife and patience.
  7. Unclefish
    Unclefish
    Northeast
    I use my flexible ultra sharp filet knife .. just got in now from doing a whole deer.. you do enough of them you will figure out where they all our. Never canned before but I know when I do shanks in sou vide for the day it melts all down and it makes it all edible....when I filet it off do it just like a fish. And if you leave a little meat you can always use a stiff not so sharp knife and and just hold on a good angle and pull silver skin away and rest of meat will come off. That usually just goes into my grind bag.
  8. Eckie
    Eckie
    My opinion is you'll never get it all. I only worry about it on the tenderloin (which is quite east to remove) and some of the large pieces on the hindquarter. But I have no experience canning, so can't say as to if it makes a big difference. I think I would try to get the big concentrations of it off if I could, like said above small sharp knife
    metalcuttr, M2theB and XXL like this.
  9. huskihl
    huskihl
    Canned venison ends up being tender about like roast beef that’s been in the crockpot all day. Almost like fish. The silver skin might detract a little bit from the flavor, but it will all be tender
  10. Casper
    Casper
  11. Redfin
    Redfin
    central Pa
    Aging the meat before processing helps a ton being able to remove that tissue.
  12. Eckie
    Eckie
    Marshel54, what's your recipe for canning deer?
    Backwoods Savage, XXL and metalcuttr like this.
  13. Marshel54
    Marshel54
    I got 4 quarts out of the meat I had.
    Not much of a recipe.
    Cut meat into 1" squares
    Pack tightly in jars
    1 bullion cube per quart
    Fill jar about 3/4 full with water
    Remove air
    Put on lid
    Process in a pressure canner 75 minutes for pints 90 minutes for quarts
    10psi for 1000 ft or less
    15 psi if over
    You can add salt, onions , garlic if so desired.
  14. Marshel54
    Marshel54
    Great video Casper
  15. The Wood Wolverine
    We canned tons of deer meat. As Kevin said, it’ll be tender when the canning process is finished.
  16. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Silver skin removal 18 or so minutes in.
  17. Eckie
    Eckie
    Thanks for the recipe Marshel54. Does anyone know if you can use an instantpot to can meat?
    We've only canned some peach preserves before, so have limited experience on water bath vs pressure canning.
  18. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Instant Pot to can no no and no. To be more correct no.
  19. Redfin
    Redfin
    central Pa
    This puffhead been hangin for 22 days at 35* or under. Processing now.
    After I cut the backbone the straps just peeled away from ribs. Granted there is waste from the outer layer drying but it is aged beautifully. Ill get a pic of the straps shortly. F6AD6A00-F64A-4527-809A-9B1962395272.jpeg
  20. Backwoods Savage
    We have canned a lot of venison and beef either by cold pack or better pressure cooker. When we first started we did not remove all the white stuff but then we tried it by removing it. We never went back as the meat simply tastes better without that crap. It is a pain removing all but worth it for the taste. Fat and that silver crap is where people get that "gamey taste."
    To can we cut in no larger than 1" cubes. Stuff them in can. For a quart add a teaspoon of salt. Then into the pressure canner.
    Redfin and eatonpcat like this.
