Removing a rusted stuck auger motor with gouged out set screw from Napoleon NPS40 wood pellet stove!
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Nov 8, 2020.
  1. don2222
    don2222
    Salem NH
    Hello
    You get what you pay for and I picked this up cheap. LOL
    First, I cleaned and tested the room blower and replaced the igniter, Ignition snap disc and hi limit switch.
    The exhaust housing flange is also loose and needs to be resealed and fastened more securely with larger self tapping screws. That the easy stuff.
    The auger and auger motor did come out in one piece.
    The auger steel set collar is really stuck and the set screw head is gouged out completely!
    I tried drilling the set screw but not much luck. :-(
    So I pulled out the plasma cutter. See pics
    Easy to cut but hard not to cut the auger. The bearing was very dirty inside so that was cleaned with a rotary brush.
    I just added a new set collar and auger motor.
    Pellets should feed much better now?
    Ssyko and wildwest like this.
  2. badbob
    badbob
    Nice work,Don.Yes,some of them old napoleons are well worth fixing,but out here the market would be bad,with NG and LPG prices being so low.But,we have the future.Thanks for the great pictures.
    Ssyko, don2222 and wildwest like this.
  3. don2222
    don2222
    Salem NH
    Hello
    There seems to be an issue with just putting a new auger collar on the auger and re-installing the auger with a new motor.
    Why did Napoleon switch to a hitch pin and an auger motor with a hole in the shaft in there newer NPS-45 pellet stoves??
    The steel collar is quite a bit smaller than other pellet stoves and so is the set screw!
    Ah Ha
    So I drilled another hole in the auger shaft, got a 1/8” diameter hitch pin and an auger motor with a hole in the shaft. So bingo this auger motor will have no more issues when being replaced in the future!
    Ssyko, badbob and wildwest like this.
