Question on a stretched chain.
Discussion in 'Chainsaws and Power Equipment' started by Dougr6, Dec 30, 2014.
  1. Dougr6
    Dougr6
    Caney Ks.
    I got careless while dorking around limbing a downed oak tree, not noticing my chain was loose, and off it came. Put it back on and its tight in one spot. It was a fairly new chain, sharpened once. I set it aside for repair?
    The drive sprocket looks okay, but there is about 1/16'' of play (in & out). This could be normal I hope! Its a Stihl ms261-cm. This is more end play then on my older ms180 drive gear.
    Now to my question,
    Are the newer stihls designed with more back and forth drive gear play, then the older ones?
    Or did I damage it and need to replace it?
    Thanks for your time.
  2. $ooline
    $ooline
    WI
    If your talking about the rim being able to move in and out against the washer and circlip its supposed to have play. This is normal and you want it this way.
    MasterMech and Dougr6 like this.
  3. $ooline
    $ooline
    WI
    Not sure what you mean by tight in one spot when talking bout your chain. Is a link binding up?
    Dougr6 and Jon1270 like this.
  4. $ooline
    $ooline
    WI
    BTW throwing chains will happen occasionally, not great for the saw, but usually pretty harmless in the scheme of things.
    splitoak, mike bayerl and Dougr6 like this.
  5. Dougr6
    Dougr6
    Caney Ks.
    When I put the chain back on and adjusted the tention. Spining it by hand is where there is one spot where it gets tight.
  6. $ooline
    $ooline
    WI
    Maybe the link your talking about is messed up on the driver underneath the cutting tooth...?
    splitoak and Dougr6 like this.
  7. Dougr6
    Dougr6
    Caney Ks.
    Thanks!
    $ooline likes this.
  8. $ooline
    $ooline
    WI
    If so file it smooth so it will go easy through the bar groove...
    splitoak, MasterMech and Dougr6 like this.
  9. Dougr6
    Dougr6
    Caney Ks.
    Ya, I will inspect it better in the shop. Thanks.
    splitoak and $ooline like this.
  10. Dougr6
    Dougr6
    Caney Ks.
    Will do. Stuck at work, but when I get home I will fix it.
  11. $ooline
    $ooline
    WI
    Ya i'm thinking the drive tooth is buggered up a little and not clearing the bar groove...maybe its ok though
  12. Dougr6
    Dougr6
    Caney Ks.
    Thanks again! 29 degrees now and 10 degrees forcast for tonight here in S.E. Kansas. Stay warm up there in Wi. And have a happy Safe New Year!
  13. $ooline
    $ooline
    WI
    Ok, thanks. I hope this advice will take care of your chain.:thumbs:if not keep posting, a pic might be useful
    Dougr6 likes this.
  14. Evanrude
    Evanrude
    Byron, MI
    Yup, this is a common occurrence on a thrown chain. Just check the suspect areas drive teeth for burs and file them smooth again.
    $ooline, Dougr6 and splitoak like this.
  15. Gasifier
    I have an 18" chain that is like this. It would get bound up in one section. The only explanation I have for that is just what $ooline is saying here. I still have the chain. Did not trade it in with my old saw. If someone wants the chain from here, they are welcome to it. I went to a 20" bar on my new saw and when I go to an inexpensive lighter back up saw it will be with a 14 or 16 inch bar. I never did fix it before I traded.
    $ooline and Dougr6 like this.
  16. CTYank
    CTYank
    CT Panhandle
    Rather than file off any raised bits on drive link(s), I take a couple of hammers, use one as an anvil and peen down the raised areas. Why throw away valuable steel? :loco: :crazy:
    If you throw chains with any regularity, it's likely because the bar is mounted to a flexible plastic chassis, rather than to engine casting.
  17. clemsonfor
    Yea like others say the drive link is most likely burred. Is that what you found? And also the drive sprocket does have some in and out play and thats normal.
    Dougr6 likes this.
  18. UncleJoe
    UncleJoe
    SC Pa
    I'll probably get a few dander's up with this but.........
    When I throw a chain and it boogers up one of the drive links, I put it back on a little loose, rev up the saw and let the bar clean it off. Takes about 2 seconds. I don't worry about the bar taking much abuse. As hard as I use my saws, a bar will usually only last a couple years anyway.
    OK. I'm ready for the shellacking. :whistle:
    Dougr6 likes this.
  19. clemsonfor
    I did this a few weeks ago as I was in the field and had one chain and no files with me at the farm period and just started my work.
    Dougr6 likes this.
  20. Dougr6
    Dougr6
    Caney Ks.
    I remember how it happened now. I was idling the saw and started to limb the log when the chain jumped off. My own fault again!
    I have not worked on it yet. Just changed out the blade for now. Happy New Year to all!
    clemsonfor likes this.
