Question about SS liner...
Discussion in 'Modern EPA Stoves and Fireplaces' started by Driver, Dec 10, 2014.
  1. Driver
    Driver
    Vinton,Va
    When or if does a SS liner need to be replaced? We are going to replace the old faithful Appalachian insert in the spring. It came with the house and near as I can determine is about 25 years old maybe more, and I'm sure that's when the liner was installed as well. Just wondering if I need to replace the liner before installing a new stove. Still not sure what stove I will be buying but I will have the dealer or a sweep check out the liner to be sure it's ok or not. Just looking for some insight here.:coffee: Thanks...
    wildwest likes this.
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    A chimney sweep with a camera would be able to tell you the condition of your SS flue.
    Might be cheaper than replacing if it doesn't need to be
    wildwest, Driver and concretegrazer like this.
  3. Driver
    Driver
    Vinton,Va
    Thanks that's what I was thinking, I really should have that done regardless since I clean it myself.
    Havn't had a pro look at it since we bought the house 15 years ago.
  4. RParrotte
    RParrotte
    Saranac, NY
    I would definitely have it inspected first. I just purchased the house I'm in now in March. The flue for the wood furnace was cracked and had to put a SS liner in. $1625!!
    Driver likes this.
  5. Driver
    Driver
    Vinton,Va
    Getting it inspected for sure, I think it's ok but want to make sure, don't want to install a new stove then a liner later on.:headbang:
    RParrotte and fox9988 like this.
  6. My IS heats my home
    My IS heats my home
    Albany, NH
    Is your liner insulated by any chance?
  7. Driver
    Driver
    Vinton,Va
    Yes....
