Quad Castile - thermocouple??
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by PoolguyinCT, Nov 20, 2017.
  1. PoolguyinCT
    PoolguyinCT
    Hi it's 1130pm & the quad is puzzling me off again.
    I ignite & only get green light in my control box- then she goes out..
    Is the green light proof of flame ? Or should I also get a red light INSIDE The control box?
    Feed gate wide open & everything else is normal to my eye..
    I have a new thermocouple, but can't find instructions to remove the cover. Is the cover fragile? Anyway to screw up a thermocouple swap??
    Thanks
    Ray
    ivanhoe and IHATEPROPANE like this.
  2. PoolguyinCT
    PoolguyinCT
    So I went ignition it again - green light
    W fire, then fire goes out green light goes out- then green light back on & fire still out.. I didn't monkey with it while I watched..
    Mother in law coming tommorow to watch kids & don't want to oil burn!!
  3. PoolguyinCT
    PoolguyinCT
    Ok - I removed & replaced.. things seems to be rolling now.. room blows kicked on... and as I finished typing my fire is dying.. I have my air switched jumped at the moment
  4. jtakeman
    Sorry we weren't much help. But us old guys need :sleeping: sometime. 5.00 AM comes way too fast. :BrianK:
    Paging kappel15 or slvrblkk
    Ifn it were me, I'd slip the cover off and carefully clean the thermocouple.. Might just be dirty and ash acts like an insulator. No see 600ºF no worky......... IIRC, you see the green and another lamp that signal its seeing fire?? But I have CRS and :confused:
    PoolguyinCT and ivanhoe like this.
  5. badbob
    badbob
  6. PoolguyinCT
    PoolguyinCT
    Thanks pigs- installed 07.. I emptied hopped, put an inspection camera inside & watched August spin. I did this because I can hear auger engage but not dropping pellets, granted I was watching spin with no load in an empty hopper.
    ivanhoe and jtakeman like this.
  7. jtakeman
    How much fines you got built up? Quads augers no likely da fines!! Could also have a pellet bridge or a few long ones stuck up top. Put a few handfuls of pellets in the pot and see if it lights. If it does and then goes out you might have to pull the auger to clear it??
    imacman, PoolguyinCT and ivanhoe like this.
  8. PoolguyinCT
    PoolguyinCT
    Had my pipe camera in there, & vacced the hopper down to the steel.
    I don't get how pulling auger comes into plays?? Can crap lurk up high in auger tube?
    I did the hand feed & fired, a short lived fire though.
    (When I had camera in, I was really hoping to find a pen cap auger like I did in 2012)
    ivanhoe likes this.
  9. PoolguyinCT
    PoolguyinCT
    Thanks badbob ..
    I have he service tech manual PDF also, if you ever need drop me a line.
    Not for nothing, but I'm not getting my blue blinker at power up anymore...
    ivanhoe likes this.
  10. jtakeman
    :eek:
    ivanhoe and badbob like this.
  11. badbob
    badbob
    No blue is bad.
    ivanhoe likes this.
  12. imacman
    imacman
    Denver, NC
    So, no blue is good?
  13. badbob
    badbob
    blue sky ok,blue smoothies ok,no blue lamp flash not ok
    PelletHound, ivanhoe and imacman like this.
  14. PoolguyinCT
    PoolguyinCT
    So get a new control box?
    ivanhoe likes this.
  15. badbob
    badbob
    If it is the older stove,don't think the blue flashing lamp stays on,only flashes code right after plugging in
    kappel15 and ivanhoe like this.
  16. PoolguyinCT
    PoolguyinCT
    Correct bob- it only flashed in power up start- but
    No blue at all at start up now
    ivanhoe likes this.
  17. badbob
    badbob
    Well your manual says it should flash 6 times,then stop,but it does not say if it stops at off or on,lol
    ivanhoe likes this.
  18. don2222
    don2222
    Salem NH
    How about checking the high limit on the auger chute to see if it tripped? There is a reset button on it.
    PoolguyinCT and jtakeman like this.
  19. PoolguyinCT
    PoolguyinCT
    Will do. But wouldn't that stopnsequence of initial ignition if tripped?
  20. badbob
    badbob
    Ya,snap disc 3 cuts all power to stove.
