Pump controller
Discussion in 'Modern EPA Stoves and Fireplaces' started by Willy, Dec 7, 2017.
  1. Willy
    Willy
    I built a wood boiler with water jacket, which is piped into shop to my heat exchangers. I need a water temperature controller to kick my circulating pump on. Would like it to kick on at about 100° or so and also shut off at 100° when I'm not home. Also my jacket holds about 40 gal and i am 100' from shop, do i need 2 circulating pumps or is 1 fine. I have a gas boiler inside that runs through my heat exchanger. Any help on finding a controller would be great, thank you. Paul
    TurboDiesel likes this.
  2. TurboDiesel
    Welcome to the club, Willy!
    Sounds like your on the right track, a simple aqua stat would turn the pump on and off at your preset temp.
  3. Grizzly Adam
    Grizzly Adam Guest
    Thats what we use on our hot water storage tank here at work. Got ours set to top out at 108.
  4. Willy
    Willy
    Thank you,
    i could probably get one at any heating and cooling shop.
  5. VelvetFoot
    VelvetFoot
    Sand Lake, NY
