proper saw starting
Discussion in 'Chainsaws and Power Equipment' started by nate, May 17, 2014.
  1. nate
    nate Banned
    Palmer, AK
    After seeing a video with several board members "drop starting" saws I just wanted to open a thread on this.
    There are MANY ways to safely start a saw, drop starting isn't usually one.
    This video shows two methods that I use.
    Also I have set the bar tip on the ground, log, etc held rear handle with left hand. This works well with a longer bar where the saw is nose heavy.
    Or I have set the saw on a flat stable surface... Tailgate, picnic table, on a log.
    The "drop start" is a bad idea because you make a pivot point with just one point of contact.
    We preach burning dry wood, chimney setup and cleaning, proper stove use, using proper PPE. I think proper saw starting is important as well.
    It doesn't cost anything nor take any longer. This isn't a 28 levels of PPE to use a butter knife situation!
    It doesn't make you less of a man for doing it "by the book". I say this because I have had SEVERAL folks comment about PPE while I was cutting. Basically to the effect that chaps or ear/eye pro was for a pansy.
    One of my friends cut his jeans and a bit of his leg and STILL insists that chaps are stupid.
    Oliver1655, IHATEPROPANE and Hinerman like this.
  2. papadave
    I tend to drop start nate.:headbang:
    I know I shouldn't, but I don't bend well anymore.
    I need to make it a habit to do the between the knees method, so I don't have to kneel or bend.
    Thanks for the reminder.
    I've recently become more mindful of putting on the brake any time I'm walkng with the running saw.
    Had a couple times where I slipped and could have cut myself if it hadn't been on.
    Chvymn99, Hinerman and Stinny like this.
  3. Hinerman
    Hinerman
    NE Oklahoma
    Good post Nate. I am of the pansy clan. I wear helmet with faceshield and ear muffs, chaps, steel toe/kevlar boots, cut resistant gloves, and start saw on ground or between knees. Hopefully, I will never need their protection. It doesn't bother me if I cut with others and I am the only one. It is a personal decision for everybody. I hope nobody gets hurt, whatever choice they make.
  4. nate
    nate Banned
    Palmer, AK
    I've shown a few folks. I try not to be OSHA nazi, but I figure if they are educated at least its their choice and not just from not knowing.
    Oliver1655 likes this.
  5. cnice_37
    cnice_37
    Proud to be a pansy.... But I do drop start with chain brake engaged. I usually can't do this with the 038, no base gasket, and no decomp.... I hear ya Nate, I do. On the small saws I can't fit my foot in the handle, and between the knees just feels awkward.
  6. HDRock
    On my 61 ,I always start it on the ground cuz there is no brake, other saws , under my thigh or on the ground
  7. firecracker_77
    firecracker_77
    IL
    I always start on the ground. Never done it any other way.
  8. mdavlee
    mdavlee
    I drop start mostly. I will start the 088 on the ground when it's got the 41" or bigger on it. I do a modified drop start when it's on the mill with the tip supported.
  9. Nixon
    Nixon
    West Sunbury,Pa .
    I generally put the rear handle under my right knee . Occasionally drop start once the saw is warmed up . Always wear my chaps ,ear and eye protection . Don't set the brake ever,and don't own a helmet . Pseudo safe ?
    DSS likes this.
  10. mdavlee
    mdavlee
    I've tried to start a few under my knee and stuff and the high compression ones will hurt you like that.
    Oliver1655 and DSS like this.
  11. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Drop started seven or eight different saws at the GTG today, glad I wasn't killed.
    the GOAT, rookie1, Carbine and 6 others like this.
  12. NH_Wood
    NH_Wood
    I start my saws on the ground for the first start of the day, but when the saw is warm and I'm cutting and moving, the rear handle goes between my legs and a quick pull to get started again. Cheers!
    HDRock likes this.
  13. mdavlee
    mdavlee
    Get you one with 200 lbs of compression and you'll only do it once. I tried and ended up doubled over.
  14. HDRock
    Always do first start of the day on the ground also
  15. NH_Wood
    NH_Wood
    Ha! Sure thing - actually, my 262xp has no decomp and she's actually a bear to pull over for 62cc (and only pulling about 155lbs) - even on the ground she'll snap at me - I usually have to start her on the ground regardless of cold or warm starts. My others saws are fine to start as I said earlier. Certainly different saws will call for different treatment. Cheers!
  16. swags
    swags Moderator
    Depends on the saw I have, the 026 for me is always a drop start. Might not be the correct way to do it but works well with that saw. Now the 064 that Carbine brought. Better put your foot on it and strap in.
    joshmain, rookie1, thistle and 3 others like this.
  17. Nixon
    Nixon
    West Sunbury,Pa .
    I guess it's different horses for different courses . It just doesn't bother me .
    Wait...... Are you saying the Moobs and Terry don't build saws with high compression ?:D
    mdavlee likes this.
  18. mdavlee
    mdavlee
    I forget the decomp most of the time. I can drop start the 088 as long as it's got a 36" or shorter bar. Terry or randy did the machine work for almost all of my saws.
  19. DexterDay
    DexterDay Administrator
    Northeast Oh
    My 460 needs a foot on handle, but smaller saws I still drop start.. :confused::bug:
    Use the brake and use common sense. You won't get killed. ;)
    Gary, great to meet you today. You had some mean saws today. Look forward to meeting you again.
  20. Hinerman
    Hinerman
    NE Oklahoma
    Me too :)
    Chvymn99 likes this.
