Proper Hydraulic oil
Discussion in 'Chainsaws and Power Equipment' started by Yawner, Nov 17, 2020.
  1. Yawner
    Yawner
    Louisiana
    County Line 25-ton splitter. Hose came undone at clamp after we replaced the hose due to a pinhole leak/failure and spewed out a bunch of the hydraulic oil. Must replace the hydraulic oil. Specs from the manual...
    Hydraulic Oil ............................................. AW32, AW46 & Universal Hydraulic Oil Hydraulic Capacity .................................................................................... 4 Gallon
    So, what's best AW32, AW46 or Universal or does it matter? The only product available locally says SAE20. I need to go back and read the fine print. I am ignorant about specs on hydraulic fluid/oil, I don't know what "32" or "46" or "universal" means in this context. Tractor Supply will have some SAE20 on sale next for $17 for 5 gallons; if that would work, that is a low price. This SAE20 hydraulic oil available local to me is $35.
  2. ErikR
    ErikR
    Deep in the woods near Cable, WI
    Some light reading for you.....
    What is AW 32 hydraulic oil?
    Page Loading in a moment AW 32, 46, 68, and 100
    Page Loading in a moment SAE in hydraulics
    The "32" and "46" is a measure of the oil's viscosity.. like "5w-30" is for engine oil... The higher the number the, for lack of a better word, "thicker" the oil is.
    If the "SAE" oil you're thinking of adding is labeled for hydraulic use, the SAE20 is equal in viscosity to AW68.... kind of thick or heavy for your splitter's specs.
    mat60 likes this.
  3. JustWood
    JustWood Guest
    Thinner oil in colder climates
    Thicker oil in warmer climates
    Yawner and mat60 like this.
