Prince wolverine valves
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, Feb 15, 2020.
  1. Screwloose
    Screwloose
    I'm considering purchasing a Prince wolverine monoblock spool valve and am looking for any feedback. Anyone use one ?
    Thanks in advance for your help.
  2. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I've never used the "wolverine" series but Prince valves are very popular on log splitters and are also found all over the place in the hydraulic industry. Just make sure the one you get is rated for the pressure and flow rate you require.
  3. Screwloose
    Screwloose
    I've used prince in the past but never the "globally sourced " ones. I'm trying to find a low gpm rated, preferably monoblock design with 4 or more spools. Open to other suggestions for sure.
    farmer steve, brenndatomu and Horkn like this.
  4. Horkn
    Aren't they all pretty much " globally sourced" now?
    That's what I'm seeing in the Supply Chain side...
  5. Screwloose
    Screwloose
    Unfortunately it seems so... but they do differentiate between their standard line and globally sourced. Space for my install is tight so a lot of custom hard lines will be used making a substitution in the future a pita.
  6. bigfrank
    bigfrank
    NorCal
    Just put a Prince valve on my splitter. Works great.
  7. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    I have a 4 spool from Wolverine that I used to make 4 rear remotes on my tractor. It had an option for a detent that I used on one spool to leave on all the time to run a backhoe or splitter.
    brenndatomu and Screwloose like this.
  8. Lennyzx11
    Lennyzx11
    Edit. My came from Surplus Center.
  9. Screwloose
    Screwloose
    That's the one I'm looking at. Glad to hear that your happy with it. Thanks!
    brenndatomu likes this.
