Plumbing advice
Discussion in 'The DIY Room' started by Pallet Pete, Mar 4, 2017.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I am finishing my basement wiring today lights, receptacles and water heater power and the next step is to start the plumbing. I have everything I need already so this is just a logistical question.....
    I have been considering a plumbing loop for natural heat convection but I ruled that out because I dont want the water heater running more to keep the water loop warm insulation or not.
    Now I am thinking about a circle water loop. Not in the recirculating fashion but an actual loop from the hot and cold water line around the basement and back to the water lines. The idea being it would give more areas to draw from and create more even pressure?
    Is that a realistic idea or am I totally off mark.
    I have all the 3/4 pex needed to do this because the water line to the house is 1" but reduces to 3/4" at the meter.
  2. Horkn
  3. TurboDiesel
    No!
    Pressure is pressure. No matter where in the system you tie in.
    Also. Use all 1/2" pipe! It will not reduce your flow. What it will do is allow the hot water to get there sooner and waste less cold water till it gets there
  4. TurboDiesel
    You can flow 14 gpm through 1/2 pipe.
    Assuming you have "normal" water pressure in your house.
    Shower head- 1.5-2.5 gpm
    Kitchen faucet- 2 gpm
    See where we're going here
  5. Pallet Pete
    Ovid
    I am doing 3/4 for a few reasons mainly its what was coming in so its what I was gonna stay with but also because I had a few loops most of the tie downs and all of the copper crimps given to me. I am really at the edge of the budget and cant buy much more. The electrical turned into a very expensive nightmare in this 100 year old house. I MEAN A NIGHTMARE! :hair::hair::hair::hair:
    All the old cloth was rotted and most of the tubes where cracked. I have pulled probably 600ft of wire in the last couple of weeks and replaced every outlet and switch I could. All I was doing was adding 6 lights in the basement except I couldnt trace anything because who ever wired this place was a moron... The upstairs kitchen fan, bathroom wall outlets, bedroom ( floor outlets under the carpet o_O ), living room fan where all on one breaker.... :headbang::headbang::headbang: Just an example. I hate this house now:rofl: :lol:
    The loop is out then :whistle: back to normal plumbing then. 1/2 is defiantly cheaper and if I purchased all of it Id go buy it but...
  6. Chvymn99
    :popcorn:... Why I think I'll join Horkn in some of that popcorn...
    NortheastAl, Horkn and TurboDiesel like this.
  7. Pallet Pete
    Ovid
    O and theres an old glass fuse box BEHIND THE WALL IN MY CLOSET! That one really really pizzed me off..... I wondered why a couple outlets where dead when we moved in.. They paneled the wall and built a closet over it o_O:loco: :crazy:
  8. MightyWhitey
    MightyWhitey
    This is a plumbing project.....................you never have everything you need...............................guaranteed at least 1 trip to the hardware store.:salute::doh:
    Elvisss222, OhioStihl, DNH and 7 others like this.
  9. Pallet Pete
    Ovid
    I will go price 1/2" at home depot and see before I go farther just how much it will break the bank with pluming. just to be sure...
  10. Pallet Pete
    Ovid
    Except I really do if I want to branch off but now I want a manifold so I dont...:rofl: :lol:
  11. Pallet Pete
    Ovid
    I am going to go think on this while I finish up the wiring. :whistle:
  12. Canadian border VT
    definitely get the manifold if doing pex.. makes every future project soooo much easier.. use more shut offs than you think you need... not really necessary with manifold but still a habit for me....
    Pete on the electrical did you take all old nob and tube out.. please Please.. do not tie Romex into knob and tube .... replace 1 entire circuit at a time if money is an issue..
    NortheastAl, Horkn, Chvymn99 and 2 others like this.
  13. TurboDiesel
    Wait!
    If you have all the 3/4 pipe, straps and everything already, use it. That will save you money, at least on the cold water anyhow. The biggest reason I say stick with 1/2" is the wasted cold water while waiting for the hot to get there.
  14. Pallet Pete
    Ovid
    Yup everything got replaced with new no shortcuts here... I am adding breakersand separating rooms and outlets too what a mess
  15. Pallet Pete
    Ovid
    I also have to replace beams that are missing because the previous owners literally cut the beams out for no apparent reason and the foundation is stone and has crumbled in one spot then they shoved a yard roller in there and cemented it... 12 years ago I thought what a great deal so it needs a little work... Now I'm older and more sore so it still needs a little work:rofl: :lol: A friken yard roller...:rofl: :lol:
  16. TurboDiesel
    So easy a caveman could do it...:D
    But it takes a lot of time!!!:hair:
  17. Horkn
    One of the most true statements ever.:doh:
  18. TurboDiesel
    Without a doubt!
    And I do it every day. You just cant think of everything when it comes to plumbing.:doh:
    Thats one of the reasons I dont do work on the side. Seems every job comes back to haunt you...:hair:
  19. TurboDiesel
    I've been a commercial plumber/pipe fitter all my life. Dad was too. No home plumbing.
    I just dont see the use of a manifold. Everyone says it saves this or that. Or future projects are easier.
    I've redone my whole house. There are no future projects. I can shut off the laundry and kitchen with 2 valves each. Anything else I can just shut the water off to the house and replace whatever is bad.
    Now, granted my house is small, but all those extra hundreds of feet of spaghetti plumbing seems unnecessary to me. JMHO
    YMMV
  20. Pallet Pete
    Ovid
    I really hate the crawl space but you have a good point....
