Plugged chimney cap
Discussion in 'Modern EPA Stoves and Fireplaces' started by bushpilot, Nov 26, 2016.
  1. bushpilot
    bushpilot
    Eastern Washington
    First: 30-NC stove, 18ft total of duraplus dvl doublewall pipe, chimney and cap, softwoods (pine, aspen, douglas fir, a little tamarack) seasoned for 2+ years.
    I installed this stove this fall. It burns well, and I have been very pleased with its performance. About 2 months of shoulder season use to date.
    This week we started getting smoke into the house when opening the door for reload. It progressively got worse, so today I finally got the chance to check the chimney (beautiful day, sunshine, 50 degrees!). It has been very rainy the last few weeks, and I didn't feel like going on the roof.
    What I found was that the chimney was quite clean, but the cap was mostly plugged. It was flakey and brushed off pretty easily. I am sure the stove will burn better now, will try later when the sun drops.
    I was up there about a month ago and had the cap off, and didn't note a problem at that time. Some heavier burning since then, and lots of rain. I do try to burn clean (without visible smoke), but towards the end of a burn it does smoke.
    I didn't have this happen with the allnighter, but then again I didn't have a screen on the cap at that time.
    So, any advice for keeping the cap cleaner? Is this a normal problem?
  2. Chvymn99
    What kinda of screen does it have? Maybe a bit small?
  3. DaveGunter
    DaveGunter
    Seems kind of odd that you say it smokes toward the end of the burn. Usually very little smoke during the coal stage of the burn. I do open the air on the 30 as the burn progresses, but that is to maintain a higher stt for more heat not because of smoke.
  4. bushpilot
    bushpilot
    Eastern Washington
    It is what came on the duravent cap, about 1/2" holes.
  5. bushpilot
    bushpilot
    Eastern Washington
    I may be wrong on that, I should get out and look again next time. But I am pretty sure that when we let it die down (leaving the house for a few hours), I usually see some smoke from the chimney.
  6. Well Seasoned
    Can you snap a pic of your cap? I think the "screened in " caps are more susceptible to clogging up than a more open model. New stove, Outside fall temps, stove is running less hot, more creosote.
    I've had 3yr oak that is supposed to be seasoned, but still bubbled a bit.
    Edit: I'll add that some stoves can be touchy..... air down, cruising along, then cut back the primary and stove loses its momentum and smokes, which is easy to do if your leaving the house. I personally wanted less air if I wasn't going to be home, rather than more air, because my jotul was a bit finicky, got pretty damm hot at times
  7. DaveGunter
    DaveGunter
    Great point, and starts from a dead cold stove you don't get a nice coal bed before loading full...I've had the bottom two outside splits still solid after an overnight burn, I imagine they smoldered a bit as the burn got to the end with the air turned down.
  8. papadave
    I don't use a screen and have about the same height flue system...all 2X wall.
    I'll get a slight bit of buildup, but it doesn't clog up like that. I'd lose the screen to see how it does.
    I do get some smoke toward the end of a burn, even with full air.
  9. bushpilot
    bushpilot
    Eastern Washington
  10. Horkn
  11. Well Seasoned
    X2 mainly animal preventative. Checking pre season your good to go. You could take that screen off.
  12. bushpilot
    bushpilot
    Eastern Washington
    The description implies it is a spark arrestor?
  13. Well Seasoned
    I think spark arrestors are required in a mfg/ mobile home setting in some states. So long as your within the 10- 3- 2 rule, your ok without it
  14. bushpilot
    bushpilot
    Eastern Washington
    Yep, I got that, and it is a metal roof to boot.
  15. brenndatomu
    A lot of people take their caps (or at least the screen) off when burning...I had one on an old smoke dragon that would plug up every two weeks...it went away for the winter...end of problem.
  16. Highbeam
    Highbeam
    I have two duravent chimneys. I bought the second one without the optional screen in the cap. I did this because the screen in my first duravent cap would clog like crazy with light brown crunchy junk above a clean flue. I took the cap apart and removed that screen.
    I do not miss climbing up onto the roof several times each winter. Yes, I've had a few birds fall in during the summer.
  17. Backwoods Savage
    I agree on cutting out the screen. It is just light hardware cloth.
  18. stuckinthemuck
    stuckinthemuck
    Make sure the screen is not required by law. On the wet side of the cascades it's not as big a deal as where it is drier and higher potential for wildfires on the eastern slope. Cutting a safety device out could open one up to liability associated with starting a forest fire. Just make sure you make an informed decision. This is an excerpt from the inspection checklist from the WA Dept of Labor and Industries.
    "Chimney system extends 3 feet above roof and 2 feet above the highest part of the roof within 10 feet of the chimney and terminated with an approved spark arrestor, and a storm collar is installed. "
    Here's the site.
    http://www.lni.wa.gov/Forms/pdf/622015a0.pdf
  19. Well Seasoned
    Good info there stuckinthemuck! I never even thought of the forest fire aspect of things.
  20. bushpilot
    bushpilot
    Eastern Washington
    Thanks, I was looking for this. I live in the woods, on the dry side of the Cascades, I think I will be leaving it alone. I'd hate to be the one who starts the next wildfire.
