Playing around
Discussion in 'The Wood Pile' started by Scout80, Dec 22, 2020.
  1. Scout80
    Scout80
    Wisconsin
    E3823683-09C9-470E-A473-8112E0F72512.jpeg 134A9F3B-8C29-4E8D-807C-CE4AB8015317.jpeg Messing around with the new tractor at the neabors place
    so far I’m really digging it. Some small things that I’d do different but nothing I can not live with.
    I definitely need to load the tires. Knew that before I did anything anyway.
    I’m thinking about building a ballast box with saw storage/chain storage.
    I don’t care for the rocker hydro shift. I’d rather have both forward and reverse up front. I knew that before also. Gona take some getting used to.
    otherwise it’s quite an impressive little rig. Fits in tight places well.
  2. sirbuildalot
    sirbuildalot
    Mass
    Nice rig!!! I really like the trailer too.
    You are correct, having proper ballast is critical for offsetting a front end loader. It will give you more traction, be more stable/safer/less likely to tip, better on hills, and take some stress off the front end components. I would recommend having Rim guard/Beet juice put in the rear's. It heavy at 11 lbs./gallon and non toxic. It also is right where you want the weight, over the tires. The 3 point wont get tied up, and can be used freely. If you want a cost effective weight box, check out Titan attachments.. They have one rated to hold 800 lbs. which would be plenty for your tractor.
    Cash Larue, Horkn, Fanatical1 and 5 others like this.
  3. buZZsaw BRAD
    Hey Scout nice to hear from you again. Havent seen you around.
    Looks like fun. Haul a few logs for me! :quad:
    Cash Larue, Horkn, Scout80 and 5 others like this.
  4. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    Very nice, that would be a very handy rig to have around!
    Horkn, mat60, Scout80 and 2 others like this.
  5. jrider
    jrider
    If it’s going to be used a lot for firewood I would strongly suggest buying forks for it.
    Horkn, mat60, Scout80 and 1 other person like this.
  6. Scout80
    Scout80
    Wisconsin
    T
    Thats the plan. Maybe even a grapple
    jrider, Horkn and mat60 like this.
  7. Yawner
    Yawner
    Louisiana
    Wish I owned it, what is it!
    Horkn, Haftacut and mat60 like this.
  8. Scout80
    Scout80
    Wisconsin
    2016 Mahindra max 26xl hydro
    Horkn likes this.
  9. Holland Dell
    Holland Dell
    SW Wisconsin
    Unless you are moving pallets, I see no reason to own forks. Look to the grapple first. However, a grapple is 4-5 times the cost of forks and the weight may be an issue. There's nothing like a grapple for moving brush piles and holding up logs will bucking.
    Haftacut, RIburn and Scout80 like this.
  10. jrider
    jrider
    You can put any heavy objects on pallets and easily move them with forks.
    Scout80, Eckie and MikeInMa like this.
  11. jrider
    jrider
    A grapple can be great but I feel you’re limited in what you can do with it. If money isn’t an issue, buy both!
  12. sirbuildalot
    sirbuildalot
    Mass
    I agree with Jrider. Tractor work involves a ton of uses besides just tree work.The forks are more useful in general. Grapples are more of a specialty implement. I use my forks a lot more than my grapple and forks are much cheaper to purchase.
    jrider, RIburn, Scout80 and 1 other person like this.
  13. Holland Dell
    Holland Dell
    SW Wisconsin
    Agreed with both. I use a track loader and don't do much tractor work other than mowing larger parcels. I do use my forks, just not as often and wouldn't be without them. I stack a lot of logs and pull them out on tight trails not wide enough for logs laying across pallet forks. For log and habitat work (90% of what I do), I would be lost without my grapple. Perhaps starting with forks as they are inexpensive and rent a grapple to try it out. I don't know what the lifting capacity is on this type of tractor. Grapples are heavy and I tend to grab several logs at a time. One thing I really like about the grapple is the ability to pick up my dirt bucket with forks inside and head to the timber with all three attachments. It's quite a sight, but it saves me a couple trips. It's even more interesting when I haul my palletized fuel tank on the forks, in the bucket and all in the grapple. I try not to do that too often as it can be a bit un-nerving. :eek: Whatever you decide, I'm sure you'll buy more toys as needed. It is an addiction and why we are all here.:D
    jrider, RIburn, Scout80 and 3 others like this.
  14. Sinngetreu
    Sinngetreu
    North Central Iowa
    That's a real nice looking set up! I'd be out there having fun too! :thumbs:
    Scout80 likes this.
  15. JDU
    JDU
    Perry County, PA
    I have a Mahindra 2415 HST 4WD. Awesome little tractor, filled the back tires with windshield wiper fluid, but beet juice would be better. If using in the snow a lot, I'd consider tire chains. Also got the clamp on forks which come in very handy. Enjoy your tractor! DSC03556.JPG
  16. buZZsaw BRAD
    My back is envious of you guys with tractors!
    Haftacut and Scout80 like this.
  17. billb3
    I have forks via Artillian pallet fork frame and use it more than I thought I would. Moving rocks, slabs, logs, stumps, big plant pots, etc..
  18. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Having good toys makes playtime sooooo much more fun, don't ya think?
  19. TacMed
    TacMed
    Texas
    I use a three point pallet mover and a 275 gallon water tote on the back for ballast.
    That way i can drain the water tote and move it by hand.
    Makes for a great ballast when I am lifting heavy loads on the front
  20. happysawer4741
    happysawer4741 Banned
    Houston Texas
    Sometimes i find myself thinking just what did i buy that for.
    buZZsaw BRAD likes this.
