Pine splits; burn better when re-split
Discussion in 'The Wood Pile' started by Skier76, Jan 6, 2018.
  1. Skier76
    Skier76
    CT and SoVT
    So a bit over two years ago, we had some pine trees taken down at our weekend house in Southern VT: I burn pine
    Cliffs, wood was cut, split and stacked by October. It's been seasoning ever since.
    But this year, it hasn't been burning that well in my stove. It would light up, but then I'd get the dreaded "Styrofoam block syndrome". Basically, it lights off fine, but kinda fizzles after that. What happened to the classic, hot and fast burn my kindling gives off?
    Not to get too nerdy about the stove...but it's a 6" pipe, quick straight run, then a 90 into an 8" external chimney, that does a 90 straight up...and the external chimney doesn't clear the roofline. So not a great setup. But it works. I've got the Euro intake plate in the stove and that helps.
    So, I re-spit some of the splits. It's like a different wood. For the latter part of last weekend and most of this weekend, I've been burning mostly pine, with some hardwood mixed in to keep the coals going. It doesn't take much to keep the stove chugging along at 500F. If I put more than a few splits in, it'll easily go past 500.
    So...lesson learned. The stove likes small splits. I've had this setup since 2009 and I'm still learning new things.
  2. TMACK
    TMACK
    Minnesota
    Sounds like a need for a moisture meter also. I can’t believe I have gone so long with out one, sure does take the guess work out of it.
    Skier76, BigPapi and Woodsnwoods like this.
  3. woody5506
    woody5506
    Upstate NY
    Small splits of anything are easier to burn. If I start a fire with just kindling and bigger splits, they will start but it takes forever to really get up to temp and stop smoking. So I try to avoid it when I can.
  4. Mag Craft
    Mag Craft
    South East Wyoming
    It seems to me it does not matter if it is pine or some other wood that the stove needs to be up to temp if I want to put in larger splits and want it to take right off and burn good.
  5. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    What if you thrown some small stuff under the big?
    Skier76, Backwoods Savage and BigPapi like this.
  6. BigPapi
    BigPapi
    The hills of Western MA
    I have seen the same, particularly with pine. But once you get her going.. look out! I always keep a mix of small and large splits with pine, since I use it often for shoulder wood where I'm starting the boiler frequently.
  7. Mag Craft
    Mag Craft
    South East Wyoming
    That can help.
  8. Timberdog
    Timberdog
    Az
    It sounds like it’s still not dry in the middle. It would be interesting to see what the moisture content is in a fresh split piece. Do you have a moisture meter?
    Skier76 and Backwoods Savage like this.
  9. Backwoods Savage
    Part of the problem is in the chimney, especially where 6" goes into 8". That can and will affect the draft a lot.
    Skier76 and Mag Craft like this.
  10. Skier76
    Skier76
    CT and SoVT
    I do have a moisture meter. I'll do a test next weekend on some of the bigger splits.
    You are correct Dennis...chimney setup is not ideal. It was there when we bought the house, so we just used it. Maybe someday we'll upgrade. But being a weekend house, cost is a factor.
    I will say, with these cold temps, splitting that pine was ridiculously easy. It just popped apart.
  11. Skier76
    Skier76
    CT and SoVT
    The battery on my meter was a bit flakey this weekend. But I was getting readings at and under 20%.
