Pine ID and other q's
Discussion in 'The Wood Pile' started by Cold is Dumb, Mar 31, 2016.
  1. Cold is Dumb
    Cold is Dumb
    Annapolis MD
    A decent sized pine fell across the access road where I cut wood. I bucked it and tossed it in the woods a few days ago, thinking I'd move on with my life and forget about it.
    Of course, my conscience got the better of me and I went back today and turned it into a stack of firewood.
    All I know is it isn't Eastern White Pine. This is in a swampy area in Maryland for native species purposes. I'm thinking Virginia Pine or Red Pine, but I don't have any experience with either. My pine-ID skills are not good.
    Pics are of trees in the area that are the same species as the one that came down. They seem to all be dying here.
    Bark pics:
    Cone and Needle pic:
    Crown, though not a particularly good pic:
    The one that fell across the road became this. It all adds up.
    Same type of tree nearby, already dead.
    Another, same type. I won't be messing with this leaner, Mother Nature can do it on her time.
    So, what kind of pine is this? What say you, FHC Braintrust?
  2. Cold is Dumb
    Cold is Dumb
    Annapolis MD
    If it is Virginia Pine, what BTU number can I expect? Not seeing it on BTU charts that I usually look at.
  3. Jeffrey Svoboda
    Jeffrey Svoboda
    Count the number of needles in the cluster. 3=red 5=white. The number of needles corresponds with the number of letters. That's about the extent of my pine knowledge. Lol
  4. Shawn Curry
    Shawn Curry
    Western NY
    Red pine - your bark looks a little different than mine but it has the same needles and cones. I just looked up Virginia pine and the cones look like they have longer 'tails' off the ends of the 'cone needles'.
    I burned some red pine this year. Dries really fast, easy to light, and it gets the house warm, but don't expect to find any coals after 8 hours. It's great for ("shoulder season") weather like this, where it's not getting below freezing but you still need to heat the house. I like it better than the poplar I burned last year (the poplar smells terrible when you burn it). It's going on the official 'menu' for my stove - I've got almost a cord in log length next to the garage to be split for next year.
    Welcome to the club! :handshake:
  5. Twindad
    Twindad
    Appalachia
    It's hard to see much detail on my phone, but judging by the length of the needles, and your location, I'd say Virginia pine.
    The fact that it is growing in a swampy area is puzzling as both red and Virginia are typically found on drier sites. That could explain why they seem to be dying.
    As far as but rating, it should be similar to loblolly, pitch or shortleaf pine.
  6. Backwoods Savage
    I think Shawn is right but the bark does look a bit different from what we typically see around here.
  7. tree killer
    tree killer
    Central me
    I don't know what Virginia pine is but that looks pretty close to scotch pine to me. Sharp ridges on bark and very sharp and stiff needles. I do better with touch than look though.
    Cold is Dumb, Star Gazer and Eric VW like this.
  8. Shawn Curry
    Shawn Curry
    Western NY
    Well, its definitely pine. I doubt you would notice much difference between any of them in the stove unless its all you burned for several years.
    Regarding BTU charts, they're all based on wood weight/density at a fixed MC, and I think the Janka Hardness scale used by woodworkers is the most accurate representation of that measurement. But for practical firewood purposes, I think you can throw all of that out anyway.
    I have 3 categories: soft (pines,poplar), medium (cherry, walnut, ash), and dense (locust, hickory). When I pick up a dry split, I can tell which category it falls into. When I load the stove, I usually run a mix; the higher the heat demand, the higher the density of the load.
  9. wildwest
    Wyoming high plains
    :eek:
    Horkn and Shawn Curry like this.
  10. yooperdave
    The bark sure looks like the red pine we have around here. Another vote for that.
  11. Paul bunion
    Paul bunion
    I thought red pine was in clusters of two needles, along with a bunch of others.
    Horkn, Shawn Curry and wildwest like this.
  12. Butcher
    Butcher
    That be red pine for sure. What variety? Who knows. White pine has a soft, almost hair like needle unlike the stiff prickers on other types of pines.
  13. yooperdave
    Ya gotta start posting more frequently, butcher!
    Horkn and wildwest like this.
  14. Butcher
    Butcher
    Spring has sprung, almost. Getting busy and time to sit here at a desk in the hooch is not an option. Work, eat, sleep and worry time has come once again.
    wildwest and yooperdave like this.
  15. Wood Duck
    Wood Duck
    Red Pine doesn't grow wild in Maryland. Virginia Pine is very common. I think it is Virginia Pine because the needles are relatively short and the cone looks like Virginia Pine. The bark of the two species is similar. The part that doesn't match Virginia Pine is the tall, straight tree you showed as an example of a similar tree. I have seen Virginia Pine grow like that in the forest, but usually they are shorter and sort of scrubby, which is why they are also called Scrub Pine.
    wildwest and Cold is Dumb like this.
  16. Cold is Dumb
    Cold is Dumb
    Annapolis MD
    Good to hear. I've tried Eastern White pine in the stove and wasn't thrilled with the results, even in shoulder season. I'm hoping for slightly higher heat value from this, but if not, oh well. It all burns!
  17. Horkn
    Yeah, definitely a red pine variety. Red pine is a much better burning firewood than white pine is.
    wildwest and Shawn Curry like this.
  18. yooperdave
    Dries quite well also.
    wildwest, Cold is Dumb and Horkn like this.
  19. Horkn
    You'll be very happy with red pine.
  20. Cold is Dumb
    Cold is Dumb
    Annapolis MD
    Thanks, Virginia Tech's tree site suggests this as well, so I wasn't sure Red Pine was the answer, though the bark sure looks close. I'll look up Scrub Pine, never heard that particular name before. Maybe that's the colloquial name around here as well for Virginia Pine.
    wildwest likes this.
