Penn Student invention saves energy
Discussion in 'Everything Else (off topic)' started by Doug, May 5, 2017.
  1. Doug
    Doug
    ohio
    XXL likes this.
  2. Backwoods Savage
    Good so long as it works but it still seems like it would impede the flow of gasses to to up the chimney. Once the gravel got hot you would not lose much heat but if the stove needed to be fired up often I would question the value. After all, let us not forget the magic heater that was "invented" back in the 70's and so many thought it a great invention...until the creosote problems cropped up big time. Heat still needs to flow up the chimney, no matter what is burning. Removing that heat to heat gravel or any other object makes me a bit suspect of it. Still, I wish them well.
  3. FatBoy85
    FatBoy85
    Washington State
    Great Idea Just basically a thermal mass in a tube. Now I don't think I wanna do that in terms of how malleable metals are with heat and weight. Its a good idea dont get me wrong but how do the coefficients work with weights like rock then with metal and heat potential and displacement or emissivity?
    If they built a way to allow the stove to heat the rock but let the exhaust out, think honeycomb.
