Pellet/Wood stove gasket vs Electric/Gas Oven Gasket
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by bostonfan49, Dec 3, 2018.
  1. bostonfan49
    bostonfan49
    Essex Junction, Vermont
    Just curious as to why a Oven Door gasket (I have seen that they come in multi diameters) couldn’t be used as a Pellet stove gasket? Our oven goes up to 700F.....I am guessing that they can’t handle the extra heat
    Thanks, Bill
    CleanFire, imacman and ivanhoe like this.
  2. ivanhoe
    ivanhoe
    Northern Ontario
    We could say the same for the glass, nah not gonna go there :zip:
    CleanFire, imacman and Lousyweather like this.
  3. bostonfan49
    bostonfan49
    Yup, I agree pretty stupid post, nuff said, me bad...
  4. Horkn
    Now you surely could find an alternative to the factory gasket by going with industrial furnace gasketing, but you'd have to do a lot of measuring, and it would have to make sense cost wise as well.
  5. jtakeman
    Never heard a stupid question.......... ;)
    I'd look into the local hardware store and see if they have rutland gasketing. I found one that replaces the Enviro gasket for far less $$ :D
  6. ivanhoe
    ivanhoe
    Northern Ontario
    Imagine all the free gasket material we find in the scrapyards :whistle:
    And yes, there's no stupid question :D
    Who says we cannot think out loud and out of the box :cheers:
    CleanFire, jtakeman and bostonfan49 like this.
  7. CleanFire
    CleanFire
    bostonfan49, They can - in fact a lot of newer stoves use the same type of gasket (stainless sheath / fiberglass core), usually the limiting factor is the mass of the door, and the alignment / finish of the stove door & frame, to create a proper seal.
    AFAIK, steel/fiber core stove gaskets are rated to 1000F, same as 'traditional' wood stove rope gaskets. But there are a lot of factors that may change this - e.g. diameter of gasket, materials used, etc.
    The old-school electric stoves that used a composite rubber seal around the door, have a deep (dished) door frame & larger air vent system at the top of the stove (top burner assembly), so the exposed gasket surface was minimal / the stove body and door frame act as the primary seal & 'heat sink' for the gasket - so that type of gasket wouldn't be suitable for use in any wood burning appliance.
    Fiberglass rope gasket is primarily used in wood burning appliances because it seals any imperfections between 2 metal parts easier, vs. stainless sheathed gasket, it can be cemented in (vs. having to be 'clipped' in, like stainless), ... and it's cheaper. ...
    I think these are the primary reasons rope gasket is used, vs. stainless sheath/fiberglass core gasket.
    BHags, subsailor, imacman and 3 others like this.
  8. BHags
    BHags
    Massachusetts
    I have worked in the retail food business for about 40 years now. And while I don't think Bostonfans question was stupid, (I didn't know the answer!), I can attest to the fact that, yes, there are stupid questions!
  9. ivanhoe
    ivanhoe
    Northern Ontario
    The way I look at it is no question is stupid but been asked over and over again points to a individual downfall:D
    We can go into specifics but rather just leave it as enough said :whistle:
    We do come across some good ones in our lifetime :rofl: :lol:
    CleanFire, imacman and BHags like this.
  10. Scot Linkletter
    Scot Linkletter
    Athens, ME
    If I melt dry ice, can I swim without getting wet?
    (I can't take credit for that stupid question. It's a Steven Wright joke.)
    CleanFire, subsailor, imacman and 4 others like this.
  11. peterfield
    peterfield
    If you’re traveling at the speed of light and turn on a flashlight, does anything happen? (Steven Wright joke)
    CleanFire, imacman, jtakeman and 2 others like this.
  12. subsailor
    subsailor
    Winthrop, Maine
    I was told many, many years ago is the only stupid question is the one that doesn't get asked.
    jtakeman, imacman, CleanFire and 2 others like this.
