Pallet pen
Discussion in 'The Wood Pile' started by jo191145, Jul 7, 2022.
  1. jo191145
    jo191145
    Ct
    Started slapping together a pallet pen this evening. This is my plan for future use. No more stacking. The end needs a little extra support but after this section it’ll get easier. Toss down some pallets on the ground. Put a cleat top and bottom. Maybe a couple splits tossed against both sides to keep them plumb and fill it up with the conveyor.
    I’ll just raise them up as I go. Should be able to reach over three sections easy enough.
    Pallets are 6 feet high. Not sure of the width,,,,never used a tape measure. Seven feet maybe?
    Length of the pen is whatever,,,,no real limit I suppose. Tho if I use 10x20 floating tarp roofs I suppose it would be easier to stop there instead of trying to tie two together.
    Plan on using the conveyor to outload them too.
    These particular pallets are a little weaker than I’d like. May start making my own out of white oak.
  2. brenndatomu
    Pretty easy to beef em up...
    :popcorn:
  3. jo191145
    jo191145
    Ct
    Yeah but not worth it IMO. It’ll be interesting to see if They can take it. Failure is always an option :)
    There’s a sawmill just down the road from me now. Those cross ties and cleats are WO I had cut up. 1 3/16” thick I felt was enough.
    A couple decent trunks and I could make my own with a pneumatic staple gun. Stronger and they should last a long time
  4. jo191145
    jo191145
    Ct
    Any mathematicians that can calculate how many cord? I’m using generic numbers of 7 feet wide, 7 feet high and 4 feet long. Coming up with 196 cubic feet. A little over a tossed cord per unit.
    Is that correct?
    Thinking it’ll be 8 feet high in the middle tapering down to 6. No need for exact measurements at this time, just wondering. TIA
  5. Yawner
    Yawner
    Louisiana
    Yes, I think your math is correct. Assuming that the 'tossed' conversion factor is correct. Which is debatable! I see various factors used. Another one of those variables that could/should be included in some youngster's PhD dissertation!
    Uh... what will keep the wood from falling out the front?
  6. jo191145
    jo191145
    Ct
    it will be a long line assembled as I go. Just placed one more section on and put the conveyor in place. Gonna give it a trial run and see what disaster unfolds :)
    I’m using 180 cubic ft as a tossed cord. Using that from memory,,,,,,,, if there are other opinions I’d be more than happy to hear it. Never saw a debate on the subject. Just a number that stuck in my head, hopefully correctly LOL
  7. buZZsaw BRAD
    Looks good Joe. How many you gonna be making?
  8. jo191145
    jo191145
    Ct
    Thousands and thousands. :)
  9. jo191145
    jo191145
    Ct
    Added one section. Wasn’t happy with three as the pallets are laid 48 long instead of wide. Maybe in the future I’ll turn them different.
    Had a little dry oak and Black Birch from cleaning that area. Next step to haul logs and buck em. AKA feed the splitter
    Could always lay the pallets on the tires and they’ll drop into position as I back up. See how it goes.
    Someday I may move the entire lift/tire system back about 20”. Too far forward IMO. That would add reach. A set of grizzly bars may add a little too. For now I just wanna make wood :)
  10. jo191145
    jo191145
    Ct
    Added some old birch, beech, hickory and that dry stick of oak to it last night. Gonna need a third bay to catch the splits. Expected as much. Thinking I’ll just get the conveyor driven on top of the pallets and build a section behind the tires, for now. Doable. Maybe even four sections.
    C6E09B85-BB5D-46B6-A6A0-ED41ACBDBB61.jpeg 2B3DFACC-3FBB-472B-A220-E432347381BC.jpeg 3428A2CB-9A9A-418F-8814-E367A0C02961.jpeg
  11. buZZsaw BRAD
    How much in each one Joe? Cord maybe? I still want a ride up the conveyor!
    amateur cutter likes this.
  12. jo191145
    jo191145
    Ct
    Should be a little more than a cord for every four foot section added.
  13. jo191145
    jo191145
    Ct
    Made a little headway today. Decided to drive the conveyor up on the pallets. Then I can just lay them behind the tires as I go. Could have added a forth wall section but I wanted to see how 3 worked. I backed the conveyor up a little too soon. It’s all a learning experience. So far everything is holding better than I thought it might.
    4530F820-B232-447F-BD5D-22CBBA52C0CB.jpeg B4AD1273-4322-4FEC-A0ED-A7310705876B.jpeg CB88129E-1D2A-48DF-ADC5-F9A9C1941A56.jpeg
  14. buZZsaw BRAD
    okay now i get it. Keep adding sections and filling as you go. Im thinking it would be on the side instead of front. Sometimes im a little slow, other times im a lot slow!
  15. jo191145
    jo191145
    Ct
    I could conceivably load from the side too. But you know how heavy that damm conveyor is LOL. Figured if I could just slide it back as I go there’s a lot less jockeying around. Have a small tow chain I connect to the splitter and conveyor with slack. Back up pull the conveyor and then just push the splitter forward again. Works good so far,,,,,,,,,
    Almost. I broke the wheels off my splitter bringing it home tonight. No big deal. I’ll weld up the retaining nut with a bigger beefier one tomorrow. Basically I used an undersized nut and bolt I had one hand that day. Too small but I wanted to drive it around and see if the entire wheels system would steer. I never replaced the temporary cheesy nut and bolt. Now I will have too :)
  16. buZZsaw BRAD
    That stinks. Im surprised youre out working on wood in the hot weather. Although it hasnt been bad humidity wise.
    Where did you end up starting the pen? Far right corner on East side of field?
    amateur cutter and jo191145 like this.
  17. jo191145
    jo191145
    Ct
    I start Obright early. Work until it gets warm. Have lunch, have a nap, go back out when it starts getting shade over there. Go back in when the dog gives me the finger :)
    It’s in the northwest corner. Just to the left of my trail that enters the woods. Early morning sun. I’m processing all the junkier wood I have that I should have processed two years ago. The Beech is still pretty good. The Black Birch not as good but still worth using. Have some tulip branches and I split one up today. That doesn’t like sitting around in log form either.
    Mostly fast drying shoulder wood in this pen.
    The Black Birch finally getting removed!!! Oh well,,,better late than never.
  18. buZZsaw BRAD
    :faint: :rofl: :lol:
  19. Yawner
    Yawner
    Louisiana
    This looks awesome, I wish I had a conveyor!
    jo191145 and buZZsaw BRAD like this.
  20. mikeward
    mikeward
    Long Island, New York
    Love this setup!
    If you have enough room and can get similar pallets just keep chugging along!
    You've eliminated a lot of handling with this net setup
    Clean out the splitter wood waste, pull forward add more pallets and keep going.
    Top cover in fall to keep leaves and snow off.
    Only two problems I see ,you have to keep moving rounds to the splitter and have to have enough similar pallets to keep going!
    Awesome novel ideas here. You built a better mousetrap congratulations!
    jo191145, WinonaRail and brenndatomu like this.
