P-38 Computer
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Iron Stove, Sep 8, 2015.
  1. Iron Stove
    Iron Stove
    Central CT
    My brother has a older P-38. We have swapped out the combustion and distribution blowers in last 2 years.
    He has had a few " Glitches" recently, as in late spring. The unit shut down once or twice. It doesn't have any lights to tell us whats up. We are thinking of changing out the computer board, since he really doesn't have the $$$ for a new P-43.
    Any advice ? I remember a member here, or more likely the other forum that had parts and such for these stoves, but figured to post here first.
    wildwest likes this.
  2. jtakeman
    Paging Lousyweather and don2222
    Can you boys help??
    IIRC the P38 board is discontinued, But they were using the p61?
  3. don2222
    don2222
    Salem NH
    Hello
    I do not have any p38 circuit boards with the knob controls but maybe Lousyweather does?
    You can update the P38 to the new control panel by installing a new wire harness, control panel and burnpot with igniter and cradle.
  4. Iron Stove
    Iron Stove
    Central CT
    That sounds like a lot of work, and $$ .
    jtakeman likes this.
  5. jtakeman
    Unfortunately, If ya can't find a NOS board. Its about all that can be done. They kind of left that stove out in the cold IMHO. Hopefully LW(Lousyweather) has another solution???
  6. Iron Stove
    Iron Stove
    Central CT
    Sent him a PM. We have time till the cold hits. Im going to do the pre season PM on the stove in next few weeks. Not a lot on the stove that could cause the issue.
  7. jtakeman
    There looks to be a retrofit kit available.....1-00-7738111
    Searched the number and found several hits. Even Amazon has listings. ;)
    wildwest and will711 like this.
  8. Iron Stove
    Iron Stove
    Central CT
    Just searched it, and see plenty of the kits, that's great. Thinking a bit more, it actually doesn't look that complicated.
    wildwest, will711 and jtakeman like this.
  9. will711
    will711
    Pocono Mts.
    Once again this place helping people out :thumbs::thumbs::thumbs::thumbs::thumbs::thumbs::thumbs::thumbs::thumbs::thumbs::thumbs::thumbs::thumbs::thumbs::handshake::handshake::handshake:
  10. don2222
    don2222
    Salem NH
    That retrofit kit is manual start. If I were to do all that I would get the Auto Lite CB and the burnpot with igniter , just my 2 cents. :)
    wildwest and savemoney like this.
  11. Iron Stove
    Iron Stove
    Central CT
    How much for the " Deluxe " kit ? Also, I heard switching a burn pot can be difficult, frozen bolts.
  12. don2222
    don2222
    Salem NH
    I have switched quite a few burn pots on Harmams with no trouble. A squirt of PB Blaster does not hurt.
    Not sure if there is a deluxe kit, you may have to buy the parts seperately.
  13. Lousyweather
    Lousyweather
    sorry, guys, into the heat of the season now (get it?!) :D
    The original p-38 boards were discontinued a couple years ago....only the brightest, best-looking, and dedicated dealers still have them, if you can find them at all. The old part number was 1-00-03769 is ya wanna help your dealer out......the retrofit kit, if you cant get the old board has been mentioned above (correctly), by Jay. Its a bit of work to do the retrofit.....you have to cut the bin, do a bit of wiring.....that kit will cost ya $225-$250 from most dealers. If you can find the old style p38 boards still, they'll run you $199 or so.
    As for making the ole P38 an auto-lighter, yea, youve got a fair amount of work ahead. New burnpot, igniter cradle, igniter, burnpot gaskets, wiring harness, circuit board.....and you'll have to modify the side of the hopper to accept the new board as well....doable, just not cheap....add the part values up sometime....disregarding labor, Im guessing it'd run $500-$600.
    Iron Stove, imacman, wildwest and 2 others like this.
  14. don2222
    don2222
    Salem NH
    Hi LW
    Great Info!
    What do u mean by?
    1. Cut the bin
    2. Modify the side of the hopper
    Just trying to follow you?
    You are best-looking, and dedicated dealer and of course the smartest! :)
  15. Iron Stove
    Iron Stove
    Central CT
    Great info :thumbs:
    Ill send you a message when I get a few minutes.
  16. Lousyweather
    Lousyweather
    yea, Don....since the "new" retrofit board is actually the "old" P61 board, the form factor is larger. Also, remember the older p38 boards were small, and mounted inside the metalwork of the stove....whereas, the bigger board requires modification of the side of the stove, therefore, cutting of the side of the sheet metal is necessary. I don't believe that the document is online in "how to" do it, but its with the retrofit kit......but still, a bit of work.....
    as far as cut the bin, well, in the P38, that kinda is the side of the hopper, but no, you aren't modifying the hopper itself, just the sheet metal surrounding the right side of the stove.
    imacman and jtakeman like this.
  17. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    Is don2222 a parts dealer?
  18. jtakeman
    IHATEPROPANE and will711 like this.
  19. don2222
    don2222
    Salem NH
    Hello
    Jay is correct.
    We now ship parts from approx 6 warehouses around the country and we just finished building approx 500 sqft of more warehouse/workshop space at the home front.
    Thanks Jay!
    IHATEPROPANE and jtakeman like this.
  20. jtakeman
    I wonder if Don offers a discount to FHC members? :whistle:
    IHATEPROPANE and eatonpcat like this.
