Outside air kit, thoughts?
Discussion in 'Modern EPA Stoves and Fireplaces' started by wfournier, Oct 1, 2015.
  1. wfournier
    wfournier
    Western MA
    Working on getting the Keystone installed and something I have been wondering about is if ir is worth getting the OAK for it. Reading around it seems like some sites say they are a waste and some people seem to like them. In theory it seems like a good concept, giving the stove somewhere else to pull air from rather than pulling cold air into the house.
    What are people's experiences here?
  2. papadave
    I put one in and it works.
    Seems to have stopped some of the air infiltration coming into this leaky house.
    Backwoods Savage and milleo like this.
  3. bushpilot
    bushpilot
    Eastern Washington
    Required equipment in WA state, but I would be putting one in anyway. My gut tells me it is better.
    Greg
    Backwoods Savage and papadave like this.
  4. Builder Bob
    Builder Bob
    Nashville, TN
    I think the outside air kit is a good idea. We had an older house and when the wood stove was burning, you could feel the cool air being pulled toward it. The wife was not fond of the draft across her feet!! The ideal steel has the OAK on it and seems to cut down on the air infiltration.
    All that said I vote yes for the OAK!
    Builder Bob
  5. HammerheadC4
    HammerheadC4
    Eastford CT
    Been wondering the same thing about an OAK.
  6. DaveGunter
    DaveGunter
    I have an OAK installed on a nc30. I only ran it for about two months without one, it does better with it for my house.
    I think most stoves have multiple inlets for combustion air, as is the case with the 30, so even if you connect the OAK, some of the combustion air will be coming from inside the house.
  7. wfournier
    wfournier
    Western MA
    I called Woodstock and asked them and the their thought was unless you have a very tight house it's not needed. They said the stove doesn't pull much air though so the additional infiltration would not be significant.
  8. Backwoods Savage
    We've had OAK kits before and also been without. Currently we are without and have no problems. The only problems we had with the OAK were mostly on windy days if wind hits and blows a lot of air in hard.
    Some homes will benefit more than others with the OAK and no doubt some stoves will work better with them. So it really depends.
    papadave likes this.
  9. HammerheadC4
    HammerheadC4
    Eastford CT
    Yesterday I went to Lowes and bought what I needed for a temporary OAK.
    When I got home I hooked everything up.
    I want to see if my house will benefit from one.
  10. bushpilot
    bushpilot
    Eastern Washington
    Looking forward to hearing your findings.
    Greg
  11. papadave
    Don't forget the pics too...........
  12. Todd
    Todd
    NW WIS
    I have an OAK installed on my Keystone, I like the theory behind it and feel every little bit helps.
    papadave and Backwoods Savage like this.
  13. yooperdave
    If you have a "tight" house, that is insulated very well, I would recommend an OAK.
    If you have a house like mine, well, just overheat it. There will be enough combustion air coming in!
  14. ChuckinMichigan
    ChuckinMichigan Banned
    Southeastern Michigan
    Also too, if you have a well-insulated and brick house, like mine, you'd need a OAK. Heck, we ran the central A/C until October 1'st here, this house holds alot of heat in the winter time. House is TIGHT! Brick House, them good thermal pane windows, triple glass, I think they're called? new roof, which helps too.
    Problem is, in this house, you really cannot run a stove, chimney is in the center of the house and no fireplace; and the water heater is gas and it's vented to it. So, a stove here is out. :( I love stoves and hope one day to own one; but not in this house. It cannot be done with making some big changes. I guess should also mention that this is a colonial house and that makes it much harder too. So, it is what it is. :smoke:
    I'll own one, one day. Just not here.
  15. colin.p
    colin.p
    Ottawa Canada
  16. jo191145
    jo191145
    Ct
    Buy a gas water heater that vents outside. Then you can use your chimney for a real purpose :)
    ChuckinMichigan and papadave like this.
  17. papadave
    Or. electric.
    jo191145 likes this.
  18. jo191145
    jo191145
    Ct
    Yep, could do that but I sure do like my gas water heater.
    As a mason when I built my house I thought two flues in the basement would be plenty. I had the intention of using one of those combo wood/oil furnaces. The furnace people talked me out of it. Efficiency was not very good in those units.
    So I have an oiled fired furnace in one flue. A wood furnace add on in the other. No hot water!!!
    I went with a gas heater that vents outside. Wasn't very expensive back in those days and it's still working after all these years without any breakdowns. Good unit that gives me hot water when I ask for it.
  19. papadave
    Here, gas would be less expensive to run.
  20. jo191145
    jo191145
    Ct
    Just switched to a new propane dealer. Filled my 500 gallon tank for $1.43 a gallon. Even filled all my empty grill tanks for me.
    The year before the company that bought out my old company wanted $4.99 where I had always been paying mid two dollars. The driver that had worked for the old company knew it was a ripoff. They're history on my property.
    milleo, papadave and Brad38 like this.
