Our game room
Discussion in 'The Game Room' started by solidwoods, Dec 13, 2014.
  1. solidwoods
    solidwoods
    N. Central Tn
    We call it The BOOM BOOM Room
    1000sf , I milled the materials and built it my self (as in no one else helped,, lucky I have a knuckle boom truck), scissor trusses and all. Hydronic heated floor + wood burning stove.
    It has a bedroom so it doubles as a guest house
    Gotter for 50clams
    Next is to install a product I make called Woodweave.
    Thin slices I make on the band mill, weave them together fresh cut and put it in a frame.
    Hang it like a drop ceiling.
  2. Freakingstang
    Freakingstang
    WOW! Awesome!
    clemsonfor likes this.
  3. PullinMyPoulan
    PullinMyPoulan
    Manistee National forest
    Nice pad:yes: You have to be an artist that woodweave something Ive never seen
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    What is your boom boom made of?
  5. solidwoods
    solidwoods
    N. Central Tn
    It's on a concrete slab with raised t/G flooring with pex hydronic heat, the walls are 2x6 insulated/shethed with 3/4 cdx
    the trusses are 2x6 with plywood/glue/nail gussets, ply on the top with sheet metal roofing.
    The name BOOM BOOM Room came from The Flintstones cartoon.
    The BBR is Tee'd onto my woodworking shop (same construction) it's 32x50'.
    Took me a yr to do the construction not including milling/drying/truing the lumber
  6. Eric VW
    Solid room, solidwoods!
    Hmmm, dart board and your in TN, me about 70 miles from Bristol.... BOOM BOOM! Love throwin darts! I really admire all the work you've done, but that slabbed shelf is the bees knees!
    Seriously, I throw darts like some of y'all have 43 cords c/s/s!
    Really, great looking work!
    Eric VanDub
  7. Woodchuck
    Woodchuck
    Southeastern Ohio
    I like the guest room. Are you taking reservations?
  8. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Very impressive work. What are you planning to finish off the cover for the ceiling trusses?
  9. Horkn
    So hydronic infloor heat, huh? Is there a boiler, or does the wood stove heat that water? How many zones?
    My dad had a plumbing and boiler business, and I worked for him for a year or so.
  10. solidwoods
    solidwoods
    N. Central Tn
    Howdy
    after the insulation is complete I'll cover the ceiling with a product that I make called Woodweave.
    It can be used as a drop ceiling panel for indoor or outdoor. I mill .01" slices on my bandsawmill and weave them together (green/fresh cut) and put it in a frame.
  11. solidwoods
    solidwoods
    N. Central Tn
    I use a Taylor woodfired water heater.
    The BBR has a wood stove also.
    I set the BBR up as 1 zone. It's 1000sf and the bedroom walls do not go to the ceiling so floor on/floor off works fine.
    Horkn likes this.
  12. yooperdave
    Looks like there's room for a pool table in there!
    Nice idea for the ceilings. Wish I had a bandsaw-mill. What kind of mill do you have?
    Can't understand why no-one would help out with a project like that.
