Osburn Matrix Wood Stove with Blower - 28"
Discussion in 'Modern EPA Stoves and Fireplaces' started by Nordic Splitter, Apr 17, 2021.
  1. Nordic Splitter
    Nordic Splitter
    WNY
    Description
    Add efficient and affordable heating with this modern and stylish stove
    • Heat Capacity: 500-2100 Square Feet
    • Maximum Output BTU/Hour: 75,000
    • Maximum Efficiency: 77%
    • Dimensions: 27 1/8"W x 36 7/8"H x 25"D
    • Maximum Burn Time: 8 Hours
    • Warranty: Limited Lifetime
    This sleek and incredibly fuel efficient wood burning stove can add keep your family warm and not break the bank. Say goodbye to high electric bills in the middle of the harshest winters. With 75,000 BTUs and a 8 hour burn time heating up to 2,100 sq. ft this stove is sure to meet all of your needs.
    You can also make this stove your own by personalizing with a steel or soapstone top and your choice of side panels. A large log storing area under the firebox will make things easy on you.
    Additional Information
    • Firebox Volume: 2.4 Cubic Feet
    • Max Firewood Length: 20" (Left To Right)
    • Emissions Grams/Hour: 1.54
    • Flu Size: 6"
    • Weight: 506 Lbs
    • Minimum Hearth Pad Size: 49" x 49"
    • Ceramic Glass Size:
    • Certification: EPA, UL 1482, UL 737
    • This model IS Pre Fab Approved
    • This model IS Mobile Home Approved
    Osburn Stoves and inserts are the premium stove line for one of the largest wood stove manufacturer's in North America. Here are some of the features that sets Osburn apart from other stove manufacturers:
    • Kiln Fired Clay Firebrick- Which hold up longer than pumice bricks to keep the inside of the stove hotter and burn the wood more completely.
    • Stainless Steel Secondary Air Tubes- Which introduce new oxygen into the firebox creating a secondary ignition which gets more heat from less wood.
    • Heavy Steel Construction- Made from a 3/16"" steel body and a 1/4"" thick steel top which carries a lifetime warranty.
    • Ceramic Glass- Which can withstand high temperatures and still allows you to enjoy the fire.
    • An Air Wash System- To help keep the glass clean when the stove is in use.
    Clean burning, non-catalytic wood burning stoves introduce new oxygen into the firebox before the smoke leaves the stove. The new oxygen is ignited, creating a secondary burn. This generates more heat and creates a cleaner burn. A wood burning insert will turn an inefficient open fireplace into a productive heat source.
    Specifications
    SKU OB02032
    Manufacturer Osburn
    Heating BTU 75,000
    Approximate Heating Area 500-2100 Square Feet
    Maximum CFM 130 CFM (Included Blower)
    Flue Location Top
    Flue Outlet 6" Diameter
    Efficiency 77%
    Amperage Requirement Less Than 5 Amps (Optional Blower)
    Type Freestanding, Single Sided
    Fuel Type Wood
    Certification EPA, UL 1482, UL 737
    Size Range Up To 29" Wide
    Max Log Length 20"
    Height 36 7/8"
    Width 27 1/8"
    Depth 25"
    Weight (in lbs) 506.0000
    Resources
    You will need Adobe® Acrobat® Reader to view PDF documents.
    Cost $3900...
    Thoughts would be appreciated.
  2. RGrant
    RGrant
    Connecticut
    I hate being ignorant, so I apologize, but what is this post?
    Ohio likes this.
  3. Eckie
    Eckie
    RGrant, I believe Nordic Splitter is posting the information about the stove, and is looking for thoughts/feedback from folks on the stove...
    Nordic Splitter likes this.
  4. brenndatomu
    I'm not familiar with this particular model, but I have had (and still do) several stoves made by the same company, Stove Builder International...they make a number of different brands, mine were (are) the Drolet line, which is like the Ford/Chevy line, the Osburn line would be more like Lincoln/Cadillac.
    The one I still have is a 1400i insert stove.
