Osage can you see
Discussion in 'The Wood Pile' started by cezar, Oct 18, 2024 at 1:01 PM.
  1. cezar
    cezar
    KY
    Fellas my MS251 has met its match. This stuff is absolutely brutalizing my saw.
    Biggest Osage I have ever seen. I committed a heinous crime by cutting it up for firewood. Main trunk 16" round, 40 foot long, and straight as an arrow. Unfortunately it's in my way and I don't have a good way to get it out of the forest except in pieces.
    I can barely lift the 16" rounds.
  2. metalcuttr
    metalcuttr
    western WA
    Terrible, terrible pun!:picard:Actually physically painful!
    buZZsaw BRAD, Chvymn99, cezar and 5 others like this.
  3. Ronaldo
    Ronaldo
    That is a biggun and I’m sure you are wishing for a little bigger saw! Look like you are gettin er done though!
  4. Backwoods Savage
    That saw will still cut it. True it takes a little longer than a bigger saw but let it work.
  5. cezar
    cezar
    KY
    I swapped to a chain with taller rakers and that did it. You really need to take slow nibbles with this stuff.
    This is a little over half the hoard. Called it quits for today. I ended up leaving the bottom 20 feet of the tree for future milling purposes. It's airborne so I have a couple years at least.
    Was an interesting project. The tree was parallel to my trail but then the top half crossed over the desired path and hung up on a maple about 30 feet up. What I did was cut a notch underneath where the tension b/w the top and bottom halves of the Osage met and then backcut the top which caused it to drop. I then took 16" rounds off the bottom and worked my way up slowly. Basically took little bites as the kerf would close up. Kept removing weight from it. Finally I got everything except the top portion:
    You can see here if I just cut the piece on the right then the vertical piece would be at (small) risk of coming back at me. So what I did was cut it 90% to weaken it mostly and then put the winch on it and yanked it to break it. Then from there I yanked the vertical portion until it flopped onto the ground and the rest was a cake walk. A fun and engaging puzzle where if you make the wrong move you die. Definitely at the 80th percentile of my skillset. I've only been using a chainsaw for a couple years and this took me all day to figure out.
    I have a new problem:
    That mark is where my X27 bounced straight off it. It laughed off my 6ton splitter. I can't afford to rent a splitter for this amount. I'm uninterested in attempting with a maul. Might have to noodle it down. IDK.
    These rounds are insane. they're 16" and easily 120 lbs. I can barely lift them.
    I did put the moisture meter on them, basically tried to keep it in a single ring to approximate the correct way of measuring a split and read 17% so these are either mostly or fully seasoned which is awesome.
  6. Chvymn99
  7. Locust Post
    That is one wood I have never had the pleasure cutting.
  8. Deererainman
    Deererainman
    Union City Ky
    MY #1 favorite firewood. Great burning firewood and can sit in your firewood stack for years and stay rot free.
    Backwoods Savage and metalcuttr like this.
  9. Deererainman
    Deererainman
    Union City Ky
    Back in the day, Dad and I worked up a lot of Hedge with McCulloch 10-10's. His big saw was a Mac Super Pro 81. Great score!
  10. buZZsaw BRAD
    Hey metalcuttr he's living on the hedge! :doh:
    Got a good chuckle out of me...of course! :D:emb:
    Nice stuff there cezar. My holy grail score. And I love the thread title!:salute:
  11. buZZsaw BRAD
    cezar try hitting it in the big center check (crack) and it should split easier.[​IMG]
