Oregon 620 or Tecomec Super Jolly; Any Difference?
Discussion in 'Chainsaws and Power Equipment' started by Ralphie Boy, Mar 22, 2019.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    So I'm checking chain grinders and I think one of the is the winner. I believe Tecomec makes Oregon so the units should be exactly the same except for the name plate and the price. Correct Wise Ones? :salute:
  2. huskihl
    huskihl
    I believe so. There's a thread on ope about guys getting them for $270
  3. huskihl
    huskihl
    Theyre $280 now
  4. Ralphie Boy
    Ralphie Boy
    $280 where? Can I get one for that price?
  5. huskihl
    huskihl
  6. Ralphie Boy
    Ralphie Boy
    Order confirmed! Free shipping, reviews to follow in a few weeks after I trash a couple of chains during the learning curve!
    :D
    Thanks for the tip! Another reason to love this place!:salute:
  7. huskihl
    huskihl
    Try 55° on head tilt, 25 chain angle, and 10 on the vise tilt. And only lower the wheel enough to sharpen with the radiused portion of the theel, not the side
  8. Ralphie Boy
    Ralphie Boy
    Ahhhh.....you've done this before! One negative review I read was you can't, as advertised, turn the head to sharpen the other side without realigning. The reviewer claimed as much as 1 mm difference in the alignment. Any truth to that?
    Screwloose and huskihl like this.
  9. huskihl
    huskihl
    You have to adjust your vise for the thickness of your drive links. If you run .050 chain through it and have it set up for it, the vise is not going to be centered if you run .063 chain through it. If that user had set up his vise properly, you could swap between left and right cutters on .050 chain all day and never adjust it
    Screwloose and Ralphie Boy like this.
  10. Ralphie Boy
    Ralphie Boy
    I figured it was 'operator error.'
    huskihl and Screwloose like this.
  11. huskihl
    huskihl
    I don't put the whole lot of faith into user reviews.
    Lol.
    :cheers:
    Ou812, Screwloose and Ralphie Boy like this.
  12. Ralphie Boy
    Ralphie Boy
    Well, it's here and it's a NICE machine! It s very well made and seems to be very easy to set up and use. I'll have to do some ' creative engineering' to mount it because I don't have a work bench or wall space to mount it.
    I think I can mount it to a base made if a couple of chunks of 2" ' 6" then clamp the whole thing to the the counter top.
    I was going to PM you but thought your answers gould help others as well.
    Out of the box, did you have to add hydraulic oil? How much and how did you get it in. The directions are a bit fuzzy on that subject.
    Screwloose, huskihl and walt like this.
  13. huskihl
    huskihl
    I don't have that model. I'm familiar with it though, as a bunch of guys on ope got them.
    I have heard they need a little hydraulic oil. Aw32, ATF, or power steering fluid would suffice
    Screwloose likes this.
  14. 94BULLITT
    94BULLITT
    Frederick County, VA
    Is this the best grinder oregon makes now?
    Ralphie Boy and Screwloose like this.
  15. huskihl
    huskihl
    There's a fully automatic one that goes for about six or seven Grand I believe
  16. OldJack
    OldJack
    Saskatchewan, Canada
  17. huskihl
    huskihl
    Do you have a bench vise? I mounted mine to a 2x6 about 16" long. I lock the 2x6 in the vise when I need it and hang it up out of the way when not in use
    Ralphie Boy likes this.
  18. Ralphie Boy
    Ralphie Boy
    No, but I do have some counter space and plan to mount it about the same way as you did then C clamp it to the counter. Probably try it sometime this weekend.
    huskihl likes this.
  19. huskihl
    huskihl
    That'll do too. I mounted mine with the board vertically where you'll be mounting yours on the bottom of it and clamping it down. It'll be perfect. I would think maybe a 12 by 12 sheet of three-quarter inch plywood would suffice
  20. Ralphie Boy
    Ralphie Boy
    Picture in a couple of days...
    huskihl and 94BULLITT like this.
