Opinions Wanted
Discussion in 'Everything Else (off topic)' started by firecracker_77, Aug 28, 2014.
  1. firecracker_77
    firecracker_77
    IL
    I have been wanting something like this for years. You could load a lot of wood outside, wheel this inside, and have a day or two wood inside with all the mess and snow melt contained. Was thinking that I would put a board cut to size on the bottom to give strength and prevent cracking from wood dropped in. Uline sells these and I've gotten their catalog for years.
    I guess I'm wondering if there are any unforeseen pitfalls like durability issues that would prevent me spending this kind of $$$... Front door is about 34 inches wide, so I'd have to be careful there.
    http://advancedhandling.theonlinecatalog.com/products/industrial-poly-box-trucks/hut-14/
  2. firecracker_77
    firecracker_77
    IL
  3. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    If the wood is wet or snow covered won't the moisture stay in the tub? On what surface are you going to roll that? It won't roll on my wet lawn. Seems like it would keep the mess to a minimum.
  4. firecracker_77
    firecracker_77
    IL
    I think it isn't waterproof cause the casters go through the bottom of the tub. On this one, I think it is waterproof.
    http://plastic-bins.apluswhs.com/cube-trucks/poly-bulk-trucks/
    I would roll this outside onto cement outside my door, unload my wheelbarrow into this, and then roll it back in and out of the way...then when I needed wood, I could roll it into the stove area.
    Nothing worse than not having wood inside when it's wet or snowing. I hate cleaning up after wood mess on the floor of the stove room. The idea was to keep the mess in the tub.
    Jack Straw likes this.
  5. Jack Straw
    Jack Straw
    Sounds good! :thumbs:
  6. firecracker_77
    firecracker_77
    IL
    milleo, Chvymn99 and Jack Straw like this.
  7. My IS heats my home
    My IS heats my home
    Albany, NH
    Good idea on the poly wheel tub, I know a few guys in here that are basement woodstove burners use them for trips from the drop (area) to stove. You could get a couple of days worth in them. GLO
    Chvymn99 and firecracker_77 like this.
  8. firecracker_77
    firecracker_77
    IL
    Here's what I got. Price including shipping was ok. Should hold several days firewood inside and dry. I'm going to silicone the hardware on the bottom for waterproofing and cut a board to fit to distribute the weight and reduce impact of logs being dropped in.
    cnice_37, Chvymn99 and Jack Straw like this.
  9. Paul bunion
    Paul bunion
    I see tubes.
    cnice_37 likes this.
  10. MasterMech
    Make a false bottom and any melted snow won't soak the bottom splits.
    bigbarf48, Stinny, Firebroad and 2 others like this.
  11. PullinMyPoulan
    PullinMyPoulan
    Manistee National forest
    plywood with some holes in it
    firecracker_77 likes this.
  12. JRSDWS
    JRSDWS
    Central Illinois
    Big tubes...and nice speakers....somebody is into serious hi-fi and appreciates the good stuff. :)
    cnice_37 and firecracker_77 like this.
  13. firecracker_77
    firecracker_77
    IL
    It has rivets on the bottom ( I thinks that what I'd call the fasteners). With plywood on top of those rivets, there will be a small gap anyway between the plywood and the tub bottom for water to collect. I like your ideas and thinking through the water situation...
  14. firecracker_77
    firecracker_77
    IL
    I live at my office desk. And I do like good sound. :whistle: :dex:
    Stinny likes this.
  15. firecracker_77
    firecracker_77
    IL
    Here's my old padded room at home that was later converted to a nursery. :loco: :crazy: The foam did reduce reflections and that room sounded awesome.
    Here's some glowing tubes for tube fans.
  16. JRSDWS
    JRSDWS
    Central Illinois
    The speakers look very familiar. Are the amp and speakers Decware?
  17. firecracker_77
    firecracker_77
    IL
    Aside from one pair of Magnepans, I buy all speakers from a small company in Kentucky...Tyler Acoustics. The black amp at home is a Classe 300 watt and the tube amp is 1962 model year Harmon Kardon Citation putting out a respectable 60 watts. That doesn't get used often since tubes overheat the space in summer. I have a 100 watt PS Audio amp driving the office speakers most of the time.
    Paul bunion likes this.
  18. Paul bunion
    Paul bunion
    I thought that was a Citation. I've heard good things about Tyler speakers but have never heard them.
    Got some tube equipment here too. Same summer heat issues.
    image.jpg These guys are in the closet for the summer. They need to wait till it is cold out. They are little space heaters drawing 1000w.
    It's a ST70 for the summer.
    (Hijacked thread w/o mention of beer, this must be a FHC first.)
  19. Woodwidow
    Exactly what I thought when I started reading this. Watch it now - someone is going to pick up on the B*** word.
    MasterMech and campinspecter like this.
  20. firecracker_77
    firecracker_77
    IL
    Sorry guys. Didn't mean to derail with off topic hobbies. Back to firewood. :axe::tree::Yar:
