Open Office and Libre office help
Discussion in 'The DIY Room' started by Pallet Pete, Jan 19, 2017.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Is anybody good with it?
  2. Grizzly Adam
    Grizzly Adam Guest
    Maybe, whats going on?
  3. bogieb
    Good with Excel, can't be too much different. But if Griz has actually used it, then he would be the better resource.
  4. CoachSchaller
    CoachSchaller
    Southeast Michigan
    very similar to excel, what do you need. I use it often.
  5. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Maybe I can tag along on this thread? Got a problem with my worksheet not putting my formulas in when I enter data in a new row. I have set up other worksheets similar to this and haven't ran into this. The SB Paid and the VAR columns have formulas that are working right. But when I insert a new row above my Totals to enter new data the formulas don't work in the new row, and then also my SUM doesn't add my new total.
    I think I can post a screen shot
    Thanks
  6. pjcalla
    pjcalla
    Indiana
    For the totals, what is the formula in the cell? It should be =sum(O8:O9) if it's just =O8+O9, it won't automatically include the new line.
    For the VAR & SB, you'll probably have to drag down the formula. If you click on the cell above it, hover the pointer on the bottom right corner, a + should show up, click and drag down.
    Sent from my SM-G930V using Tapatalk
  7. Gary_602z
    Gary_602z
    Had the right formula for the totals. Basically what I want to do is to click on row 10 hit insert and be able to insert my data with the last 2 columns being calculated along with the totals without having to drag or copy the formulas. I have an A/R sheet that I set up that does it. I am sure I am just doing something stupid on this.:):):)
    Gary
  8. Gary_602z
    Gary_602z
    I see my formula for my column SB PAID is
    =+D8+E8+F8+I8-H8 could this be the wrong structure?
    Gary
  9. pjcalla
    pjcalla
    Indiana
    Instead of adding the row at the very end, try adding it between the two established rows. I always leave a few rows at the end, until the final draft, so adding rows is easier.
    Mitch Newton likes this.
  10. pjcalla
    pjcalla
    Indiana
    No, if its calculating the right way, should be good.
    Instead of dragging it down, you could double-click on the "+" and it will fill down to the end of the column.
    All my experience is with excel, but I'd imagine they're the same.
  11. Gary_602z
    Gary_602z
    I think I had tried that early today, I will try it again tomorrow at work.Just on laptop now and just don't feel comfortable on it!
    Thanks
    Gary
  12. Pallet Pete
    Ovid
    Sorry fellas I forgot I started this thread......:picard: So much else going on here.:whistle:
    I found my office 07 discs finally. I have lost my office touch so to speak.:hair: Grizz helped me with what I needed done. :thumbs:
    Keep this one alive I bet a lot of people will end up chiming in here on open office and libre office for help.
    bogieb likes this.
