One Sided Firebox
Discussion in 'Modern EPA Stoves and Fireplaces' started by MightyWhitey, Nov 7, 2014.
  1. MightyWhitey
    MightyWhitey
    Y'all ever get those fires that are "all" on 1 side of the firebox and not the other???
    I do my best to rake the coals forward evenly, and still I wind up with this phenomena at times!!!
    It always burns over to the other side....................just a wondering!!:cool:
    HDRock and Gark like this.
  2. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Door gasket leaking ?
    Well Seasoned likes this.
  3. mattjm1017
    mattjm1017
    Ive had that happen sometimes I chalked it up to the wood maybe being not very good? I dont know if one side of split can be more seasoned than the other?
    MightyWhitey likes this.
  4. MightyWhitey
    MightyWhitey
    Nope.
  5. Backwoods Savage
    Most times it has to do with how that air comes into the firebox. Even on our Fireview, we find that the wood burns a bit faster on the left than on the right. Not a big difference, but there is some difference for sure. I've talked to others that have stoves that are a lot that way. The wood still burns good and the stove gives heat and that is what counts.
    macpolski, Gark and NYCountry like this.
  6. jeff_t
    jeff_t
    SE MI
    My king will do that. I figure it's the really wide firebox, and it's loaded n-s. Wherever it starts burning is where it burns. Seems like it is where it has the best airflow up thru a gap in the splits.
    It is especially noticeable this time of year when I don't reload on very many coals.
    Beetle-Kill likes this.
  7. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    This is an NC-13? What are the gaps-(if any) on the baffle material between the sides?
  8. My IS heats my home
    My IS heats my home
    Albany, NH
    It's a fire with a mind of its own. Maybe a fireside chat will get it back to normal.
  9. Gark
    Gark
    SW Michigan
    Both of the EPA stoves I've run have done that: always seem predisposed to light & burn on the right (east) sooner. Some wierd earth magnetism anomaly causes it, I suppose.
  10. Beetle-Kill
    Beetle-Kill
    I'll throw this out there- If I recall correctly, a person on another "site" added a stick of welding rod covered in gasket material to close the gap between the baffle material and the side of the stove, in an NC-30. That closed about a 1/4" gap and made the stove run better. Check for gaps and see if that might help.
  11. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I see this happen on my VCs often.
    Gark likes this.
  12. bogydave
    I load N/S
    On a new load, after it's full ,'
    I lay a small piece, thin kindling size piece E/W
    Right in front, on the bottom.
    Falls down on or near the hot coals.
    It lights off quick, & in a short time, it moves the fire/flames along the whole front.
    pieces with a little birch bark , light & burn pretty fast
    but all wood ones work too, just not as fast acting.
    jeff_t and HDRock like this.
  13. HDRock
    I do that sometimes to, a small piece across the front it works really good to help get it going quick but, my stove seems to like to burn on the right, East side first but sometimes it will burn up the middle first then go to the right side then left side, I think it depends a lot on the gaps between the wood , cuz also sometimes my stove will burn even all the way across
  14. MightyWhitey
    MightyWhitey
    Could be...............I've been burning a lot of ug
    One solid baffle pieced baffle. Snug to the back and on the sides, sitting level.
    This doesn't happen all the time...............just occasionally.
  15. yooperdave
    Doesn't apply here, but on my OWB, I intentionally build the fire on either the left or right side just to use less wood. As the temps drop and it gets cooler, I have to give up this practice.
    As far as the 13 goes, I have yet to experience what you are describing.
  16. Gark
    Gark
    SW Michigan
    The Encore cat 2550 (no longer part of the family) would light and burn so heavily on the east side that I tried all kinds of things to counteract it. Mostly, shoving a the hot coals to the west and placing the load far east. That stove was imbalanced in other ways too.
  17. Todd
    Todd
    NW WIS
    Both of the WS Keystones I've had burned more on the left than right. I always just thought it had something to do with the construction of the fire box. The left side has 2 layers of soapstone while the right side has a single layer and loading door.
  18. bogydave
    Some of that random Mother Nature's rules of physics.
    Radom:
    Air pressure, air temperature, stove temp, flu temp, wood type, wood moisture wood spacing , wood placement , wood dimensions
    & the "butterfly effect "
  19. Gark
    Gark
    SW Michigan
    The Heisenberg Uncertainty Principle asserts itself inside our stove every burn. LOL.
  20. bogydave
    +1
    Add in "Human" variables. Could get scary if you thought about it much. :bug:
    Gark likes this.
