One days burn
Discussion in 'The Wood Pile' started by Cold Trigger Finger, Feb 11, 2018.
  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Beins it's been chilly here lately. I 20180210_165330.jpg 20180210_165312.jpg thot I'de take a pic of how much wood I burn in 24 hours. MS 251 with 18" bar for comparison purposes.
  2. Midwinter
    Two sleds worth a day?
    Eric VW, Mag Craft, FatBoy85 and 3 others like this.
  3. NH mountain man
    NH mountain man
    WMNF N.H.
    Thanks Cold Trigger Finger , I was wondering how much you burned with those temps you have up there every night. :shiver:
  4. farmer rob
    farmer rob
    Dundalk Ontario Canada
    Nice to see another burns poplar and some sort of pine tree.I will guess that about all that grows way up there?
  5. Backwoods Savage
    Nice. For sure you burn much more than we do. But be happy you have that rather than depending upon oil. Well, oil for the saw is okay...
  6. TurboDiesel
    I love that little sled, CT Finger!:handshake:
    I burn about 8-10 splits in each load. Each reload burns about 8-12 hours. I figure I burn about 1 split per hour, or 24 splits per day. Or a cord in 5-6 weeks.
    There was absolutely no science in my math. :emb:
    All estimated averages, of coarse. :yes:
  7. Cold Trigger Finger
    Cold Trigger Finger
    Just 1 sled load per day if the wind isn't blowing and the temperature is 30 below and warmer. All poplar last longer than mixed with spruce.
    I took a couple pics to show the size of wood and saw better.
    I did get most of the cabin banked with snow good which Really warmed it up in here and reduced our wood usage by 1 huge armload per day.
  8. Cold Trigger Finger
    Cold Trigger Finger
    I guess the 2 pics are a bit misleading, sorry I didn't think about that.
    Depending on the ashes in the stove . I can put about 4 pieces of wood in at a time. At 30 below, running the draft somewhat open I'll get 3 1/2 hours on that with it putting out good heat. At night I cork it down and get a full 8 hours. The Toyo helps take up the slack by morning
  9. Cold Trigger Finger
    Cold Trigger Finger
    In other parts of the Interior there is lots of birch . I is better firewood than poplar or spruce. We have very little birch close to where I live. So I burn mostly poplar as I like how it makes coals better than white spruce and somewhat better than black spruce. . I also burn cottonwood when I come on it where I'm getting firewood.
    Poplar is nice because it's easy cutting and processing beings it doesn't have lots of limbs. And it splits relatively easy.
  10. dingbat
    dingbat
    Western Northern Cackalaky
    Stacks almost as easily as Legos too.:thumbs:
  11. Locust Post
    I have never burnt much poplar but have about 2 cords ready to process so I will be burning some in the future.
  12. billb3
    I've only burned poplar once recently and I'm guessing it's a fairly crappy version of the poplar that grows north of the border.
    And I let it season a second year. Big tooth Aspen actually which is supposed to have a bit more BTU than the brown bark poplar we also have.
  13. Cold Trigger Finger
    Cold Trigger Finger
    Aspen and poplar are in the same family. On the small diameter stuff I run a kerf thru the bark and stack it need up. On the splits, I stack bark down split up. It dries nice that way. The wood is porous but the bark is waterproof.
  14. billb3
    I only kept anything big enough to split. Actually I think the one I cut down was one of the first victims of the gypsy moth outbreak we had here for about 5 years. Hoping it's 'had' as I see no egg masses this year. But we still have Winter moths. Poor trees can't catch a break.
  15. Cold Trigger Finger
    Cold Trigger Finger
    I think Aspen and poplar are kinda about the same coast to coast.
  16. Backwoods Savage
    But one has to be careful with that thinking because in the east and south there is much yellow poplar and that is something totally different.
    Cold Trigger Finger and Eric VW like this.
  17. Eric VW
    Neat point.:yes:
    We burn a tad less than that/cold day, but haven’t had any snow (nor ever near that amount) to bank....:D
  18. farmer rob
    farmer rob
    I learned a new term from you Sir (Banked) I was wondering if anyone else did that with as much snow as can get around the house. I had mine over 4' high all around there during Christmas when those temps were nasty but then it happened again rain and mild for 3-4 days Grrrrrr. but once again 3 sides over 4' high and keeping fingers crossed not much rain in the future. Again thank you.
  19. Cold Trigger Finger
    Cold Trigger Finger
    The stuff I call pople/poplar here is very similar to the poplar we logged in Maine. Which is very similar to Aspen .
    But, I know there are lots of different tree sub species that have the same or similar names.
    Like the difference between alpine hemlock and western hemlock.
    They are both hemlock but Alpine isn't nearly as strong as western for lumber.
  20. Rowerwet
    Rowerwet
    Seacoast NH/MA
    This is one days burning for us, it sits on the back sun porch, so my wife only needs slippers to feed the stove
