Older Pellets
Discussion in 'The Pellet Bag' started by titanracer, Jan 15, 2017.
  1. titanracer
    titanracer
    Newville, PA
    Pellets have a certain amount of moisture built into them when manufactured. They tell you to store them in a dry moisture free area. But after being stored for several years in cool dry area, is it possible that the moisture content in the pellets could drop lower than the moisture content at time of manufacturing, and change the way they burn.
    IHATEPROPANE and CleanFire like this.
  2. subsailor
    subsailor
    Winthrop, Maine
    Don't know but if they were dryer I'd think they would be hotter and faster.
  3. CleanFire
    CleanFire
    Are they burning cooler, or hotter?
    Only ask because we've been burning 2 yr. old stock stored outside in the woodshed (roofed, and stored at the back & dry, but exposed to outside air), and we've been opening them inside / letting them 'air out' for a few days before roasting.. They've been burning good. Just curious.
    IHATEPROPANE likes this.
  4. savemoney
    I have had some 3-4 yrs old that were stored in a detached garage. I noted condensation on the bags from time to time, but to honest, they burned just the same as when I first bought them.
  5. Scot Linkletter
    Scot Linkletter
    Athens, ME
    The moisture content is usually 5% - much dryer than wood can naturally get by air-drying (or "seasoning"). They won't get any dryer but they can absorb moisture and become wet if they come into contact with water. Humidity in the air doesn't seem to affect them.
    Orson_Yancey, gbreda, artc and 6 others like this.
  6. CleanFire
    CleanFire
    Thank you for the feedback Larry & Scot. :yes:
    savemoney, IHATEPROPANE and jtakeman like this.
  7. Lousyweather
    Lousyweather
    yea, keep em dry, youre good. You can get a little exfoliation off of the individual pellets, and likely you'll see an increased moisture content, but not likely enough to make a difference. The more moisture there is will eat into the BTU output (it takes BTU's to drive off moisture). I ve a damp basement, and have had pellets have birthdays down there, to no ill effects!
  8. CleanFire
    CleanFire
    Thanks, will keep them high & dry here LW. :yes:
    Good to know they can celebrate Birthdays w/ no ill effects, I'll buy them a Beer. :thumbs:
    :cheers::cheers::cheers:
    will711 and jtakeman like this.
  9. nailed_nailer
    nailed_nailer
    Cape Cod
    We woodworkers know all about this. Google EMC (Equilibrium Moisture Content)
    Its what makes Aunt Bessy's 200 yr old China Hutch from Arizona have sticky doors when you move it to Florida in the summer.
    Ambient moisture in the surrounding air causes wood cells to shrink/expand with moisture.
    The USDA Forest Products Lab has a Book on all things wood.
    https://www.fpl.fs.fed.us/documnts/fplgtr/fpl_gtr190.pdf
    In particular Chaper 4. Moisture in wood.
    I harvest my own turning stock from local standing trees.
    Logs or timbers have two types of moisture.
    Free Moisture.....what is contained between the cells of the wood. And,
    Bound Moisture...what is contained within the cells.
    Free Moisture flashes off fairly quickly once timber is cut
    Bound Moisture takes quite a while to dry to ambient. General rule of thumb is 1" per year.
    The trick to drying timber is you want to do it slowly and evenly to prevent cracks (checking)
    Pellets being heavily processed sawdust won't suffer much from Free moisture unless they get soaked or submerged.
    But they will contain Bound moisture as any wood will.
    The storage of pellets will affect how much ambient moisture they absorb/release.
    There is also a bit of "Case Hardening" on molded pellets and this will affect the absorption rates. How much I'm not sure.
    The plastic storage bags will go a long way to reducing quick changes but in long term storage it wont make any difference.
    Just like the varnish on Aunt Bessy's Cabinet.
    It basically comes down to surface area exposed.
    I would guess (My guess) the 1"/year general rule of thumb also applies to bagged pellets
    The pellet storage bags and the actual pellet surface will determine how much moisture is absorbed/expelled
    So bagged pellets with several years of damp basement storage will have been affected ~2"-3" on all exposed sides. Perhaps more depending on how tight they are stacked on the pallet.
    So Back to original question......
    Yes, Pellets stored in dry cool basement could have lower moisture content then when they were manufactured.
    ---Nailer---
    Russell, jtakeman, slvrblkk and 2 others like this.
  10. Tullytown
    Tullytown
    North of Phila Eagles.
    same here but we call it a cellar if there is no living space just storage...:p
    CleanFire, Russell and will711 like this.
  11. gbreda
    gbreda
    NH
    My LaCrete have been in the basement for over 2 years now and they are right next to the stove-so very dry in the winter and a bit humid in the summer. No ill effects at all.
    IHATEPROPANE, CleanFire and slvrblkk like this.
  12. slvrblkk
    slvrblkk
    Northampton, PA
    I have pellets easily a few years old, they're like a fine wine (or woman).....treat it right and it gets better with age :D
    will711, IHATEPROPANE and CleanFire like this.
  13. Tullytown
    Tullytown
    my skids of pellets are about 10 feet away from our oil furnace that kicks on
    quite a few times per 24 hrs for domestic hot water.
    prob helps keep them dry.
