Old hammer
Discussion in 'Everything Else (off topic)' started by trapper brad, Aug 16, 2022.
  1. trapper brad
    trapper brad
    Arkansas
    I found this in a field that dad and I were cutting hay on for the first time. Was wondering if anyone has seen one like it. That's a 16 Oz bottle for size comparison. It weights 16 pounds. I've seen smaller ones like the blacksmith hammers. 20220816_103016.jpg 20220816_102949.jpg
  2. yooperdave
    Lineman’s hammer
    The lineman’s hammer is traditionally associated with the task of hammering bolts or large screws into materials such as utility poles. It may appear very slight in structure and design but the principle is the same with two rounded hammerheads and a handle designed to absorb shock – often enhanced by rubber grips.
    Similar?
  3. walt
    walt
    north central ohio
    I have not seen one like that. I would haft it and use it I like a 16 lb hammer
  4. trapper brad
    trapper brad
    Arkansas
    Definitely going to put a handle in it. I'm a heavy equipment mechanic and use one nearly every day. May not use this one much but will swing it some.
  5. Screwloose
    Screwloose
    Does that have a socket for a handle?
    If not I suspect that it is a backup dolly that used to be common when things like boilers were being hand fitted.
    Nice to have as a backup for driving pins ect.
  6. trapper brad
    trapper brad
    Arkansas
    Yes it does have a socket. Still has the last little bit of wood left in it with a metal wedge.
  7. JD Guy
    JD Guy
    Upstate SC
    Thanks for sharing, looking forward to finding out what it's original use was.
  8. Warner
    Warner
    My shoulder hurts just thinking about swinging that thing.
  9. trapper brad
    trapper brad
    Arkansas
    I swing one alot putting d-9 and d-10 blades together. Also taking the stick, bucket, and boom apart on the big track hoes when we move them
  10. trapper brad
    trapper brad
    Arkansas
    20220817_093744.jpg It had two metal wedges and two steeples in the broken haft
    M2theB, Chud, walt and 5 others like this.
  11. trapper brad
    trapper brad
    Arkansas
    Looks to have been turned on a lathe
    walt, M2theB, Chazsbetterhalf and 2 others like this.
  12. Screwloose
    Screwloose
    Definitely.
    Pretty substantial persuader !!
    M2theB, jtstromsburg, walt and 3 others like this.
  13. MasterMech
    I wonder if it's "soft" hence all the deformation around the edges? It would be quite unusual for such a large hammer head to be turned from a billet. Homemade?
    M2theB, Screwloose, JD Guy and 3 others like this.
  14. trapper brad
    trapper brad
    Arkansas
    Definitely not soft. A file will barely cut it. When I get it rehandled I will find out how hard it really is
  15. JD Guy
    JD Guy
    Upstate SC
    Is one working end larger than the other or is it a optical illusion of the picture?
    walt, trapper brad and Screwloose like this.
  16. trapper brad
    trapper brad
    Arkansas
    Same size on both ends
    walt, JD Guy and Screwloose like this.
  17. trapper brad
    trapper brad
    Arkansas
    I was guessing on the weight, comparing the size to a modern 16# sledge but I was wrong. We weighed it today at work and it's 22#,s
    M2theB, jtstromsburg, JD Guy and 5 others like this.
  18. MasterMech
    Does it say "John Henry" on it? :dex::D
  19. trapper brad
    trapper brad
    Arkansas
    Got a handle in 'er. Over 22#s man killing iron. I'll drive a few pins with it then take it home. 20220823_072454.jpg
    Chvymn99, walt, M2theB and 4 others like this.
  20. buzz-saw
    buzz-saw
    Ct.
    That is cool , I like the shape.
    Reminds me of a hammer you would see in an old cartoon.
    Chvymn99, walt and trapper brad like this.
