Occasional downdraft on my stove
Discussion in 'The Wood Pile' started by Stoveaclaus, Nov 17, 2019.
  1. Stoveaclaus
    Stoveaclaus
    Long Island, NY
    Occasionally, i think when its damp, i have trouble getting my stove drafting. I can feel the downdraft when i open the door to it. My stove is in the basement. As soon as i get it going its fine but i usually get a bunch of smoke in the house. I will occasionally use a hair dryer to reverse the pressure. Anyone have any other ideas that they have used with success?
  2. OhioStihl
    OhioStihl
    Southern Ohio
    Propane torch. Aim it in the stove towards the flue. Hold it there longer than you think you should then light the stove. Basement installs can be finicky.
  3. Eric VW
    Candle or torch (hand held portable propane).
    Some folks light a piece of crumpled newspaper too.
  4. Slocum
    Slocum
    North Central Indiana
    I also have a stove in the basement and have the same problem when it’s in the 40s with rain and a cold stove. Usually I can open the basement door to correct the draft. On occasion I have to take the cap off of the bottom of my tee outside of the basement where my stove pipe goes through the wall. My basement is day-lighted on the backside of house so it’s convenient for me to do that.
  5. Eric VW
    I guess we’re fortunate that our chimney is centrally located thru the house. Very infrequent to have to correct the draft here. :yes:
  6. Stoveaclaus
    Stoveaclaus
    Long Island, NY
    I usually blast a couple loosely packed pieces of newspaper but it releases a lot of smoke into the basement before it starts drafting. Anyone use a heat gun? Thinking about buying one
  7. Slocum
    Slocum
    It’s not a big deal. Only have a problem when the stove is cold which isn’t very often.
  8. Stoveaclaus
    Stoveaclaus
    Long Island, NY
    I burn every day in the winter but i never have a burn last from night until morning. Since my fiance and i work during the day i dont light one before we leave for work. I set the heat at 62 and light a fire when i get home at night.
  9. The Wood Wolverine
    I've had mine do that 2 or 3 times in 10 years. I couldn't tell you conditions because I wasn't paying enough attention and didn't write anything down. Mine stays burning all the time so it's not an issue for me. Be interesting to know the science in what is happening.
  10. Buffalo Plaid
    Buffalo Plaid
    Pepperell, MA
  11. Stoveaclaus
    Stoveaclaus
    Long Island, NY
    I feel like damp air is heavier so it creates a downdraft, but then again im just a rambling idiot.
  12. Eric VW
    Technically, if your chimney is external to the envelope of the home, you will get a “cold air plug” that prevents draft initially.
  13. Slocum
    Slocum
    I have a friend that has talked about using one. He said it works for him.
  14. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    That’s what I do. In fact, time for a fire so I’ll get it going and take a pic
    I open the bypass and shove the end of the heat gun right into the flue opening and use a short piece of I-beam and chunk of farwood to prop it up. Usually let it run a couple to 5 minutes or until the pipe feels warm a couple feet above the stove. PO had a T in the flue before it turns to go out and would pull that plug and set the heat gun there. I may try that sometime too.
  15. Brad M
    Brad M
    Pleasant Hope MO
    When I lived in Wisconsin my stove was in the basement and I used a heat gun when my stove pipe had a cold plug. The wadded newspaper trick ALWAYS filled my basement with smoke. My stack was just too tall for that to work. The heat gun worked good!
  16. Stoveshamster
    Stoveshamster
    Long Island north Shore
    I think your issue is that your pipe has a couple of angles as it leaves your foundation and goes up your house. Tough to heat that thing on a cold damp day. I say for the damp days some kind of small fire starter lit for a few minutes like one of Backwoods Savages super cedsrs
  17. Stoveaclaus
    Stoveaclaus
    Long Island, NY
    You sold me on it. Harbor freight here i come. No sense buying a good one for this endeavor. Thanks!
  18. Bobby Maple
    Bobby Maple Banned
    Long Island
    Try some newspaper towards the flue
  19. amateur cutter
    Anything that makes heat without smoke will work. Good luck!
  20. brenndatomu
    You can sometimes get draft to "correct" on basement installs by cracking a nearby window open a bit until things take off...
