OAK Termination
Discussion in 'The Wood Pile' started by MightyWhitey, Jan 6, 2017.
  1. MightyWhitey
    MightyWhitey
    Would y'all with OAK's mind posting some pix of how you terminated it outside your house please?? Or just describe it??
    I've definitely come to the conclusion that when it's this cold here for any length of time; that I cannot be pulling air to feed my stove from the crawl space. It causes the bitter cold "outside" air to be pulled into my crawl space via the crawl space vent and makes the space, and thus my floors very cold. That in turn gets transferred into the living space, and my stove just cannot keep up then.
    Thanks.
  2. papadave
    I just used a dryer vent termination, but pulled out the flapper. Hooked up a stainless flex hose inside to the stove. Done.
    Cheap and very functional.
    Once done burning for the year, I stuff insulation in from the outside so the critters stay out.
  3. DaveGunter
    DaveGunter
    Ditto
  4. bushpilot
    bushpilot
    Eastern Washington
    I will be doing the same, but leaving the flapper on, with a clip to hold it open in winter.
  5. Babaganoosh
    Babaganoosh
    Jersey Shore
    You would think a company would have come up with a good one by now. Maybe even a screen in it or a plug that goes into the end once the burning season is over.
  6. TurboDiesel
    Sounds like you have an invention there!
  7. Babaganoosh
    Babaganoosh
    Jersey Shore
    Yeah I thought about that once I posted it. You could have separate heads on it for the burning season and the rest of the year. You could put the burning season head in the stove to remind yourself to swap them out.
  8. Horkn
    I'd love to put an OAK on my Quadrafire, but I don't know if it's possible on my model.
  9. yooperdave
    This being galvanized, it can be painted to compliment the color of your house.
    I would also consider using insulated flexible pipe for the crawl space if you don't heat the crawl space.
    I would think your crawl space has heat in it though, in order to avoid freeze ups?
  10. Oldman47
    Oldman47
    Illinois
    That looks like a standard OAK end fitting Dave. At least it looks like the one that I got with my OAK. I did add some insulated dryer vent to extend mine to reach though. The bit that came with the OAK was way too short.
  11. yooperdave
    Yup, screen already in place and not dampered to the outside.
    Backwoods Savage and papadave like this.
