Oak slabs.
Discussion in 'The Wood Pile' started by Heat550, Dec 19, 2017.
  1. Heat550
    Heat550
    Minnesota
    Has anyone burned oak slabs in there boiler?
    Learned so far turn boiler down by 20 degree. They burn hot.
    Heat550[​IMG]
    Sent from my LG-H900 using Tapatalk
  2. FatBoy85
    FatBoy85
    Washington State
    I have oak 2 by 6’s that are cut about a foot long. Been waiting for it to get really cold before using them. Won’t be long.
  3. Heat550
    Heat550
    Minnesota
    They get hotter then you think. I'm ready for a polar vortex. lol
    Heat550
  4. yooperdave
    I got a load back in the 90's that lasted two years. Pain to fire up and didn't last as long as large rounds do, but I think the truckload was $150!! Well worth the inconvenience now-a-days! About 1/2 price of a regular load then. I remember the truck being a bit larger than the one in the pic though.
    If you don't mind saying, what did you have to pay for that load?
    I did not turn the temp of the OWB down though...didn't have any concerns that I needed to.
    I left the banding on the bundles and cut the slabs to length...off each end of the bundle first, then once through the center of what was left of the bundle. Then, with those two portions left, halved each one. That make sense?
    Ended up with 5 sections close to 20" long slabs. Or, cut them into 24".....each bundle would be four cuts.
    Is this the first time you'll be burning slabs?
  5. Heat550
    Heat550
    Minnesota
    I just one cut in the center . Boilers 54 inchs .. I might of payed a bit much . But I wanted to try them they work great .. I would only buy oak debarked. They burn super hot . Boilers 300 cfm forced draft.
    What's going rate per bundle there. I'm long ways from the mill so trucking is a issue in my location.
    Heat550
  6. yooperdave
    That price was around 25 years ago!
    Last time I checked on a bundle of oak slabs, they were $45 a bundle. And thats almost exactly one cord of wood with no air space!
    Forced draft, huh? Now I understand the need to adjust aquastat!
    Backwoods Savage and Hammy like this.
  7. VOLKEVIN
    VOLKEVIN
    Shenandoah Valley, Virginia
    Where did you source them from? Lumber yard? Mill? And, how'd you get them off the truck- do you have a tractor or fork lift at your place?
  8. Heat550
    Heat550
    Minnesota
    Yep they go atomic . I put cap on the chimney extensions to slow things down
    Stove can stop a roaring slab fire but it jumps water temp 20 degrees after draft fan shut off.. yes it's same price here plus 15 for trucking logs go for $137 cord here now. All oak. What about oak there what does it run a cord logs ( real cord )
    There is fuzzy math out there when comes to logs on a truck.
    Heat550
    Backwoods Savage and yooperdave like this.
  9. Heat550
    Heat550
    Minnesota
    Truck has a clam ... Mill.
    Heat550
    cre73, Backwoods Savage and FatBoy85 like this.
  10. yooperdave
    We can still get cords for no less than $100 but it is a mix of hardwoods. Some loggers charge $125
  11. Heat550
    Heat550
    Minnesota
    Yes I can get mixed here for that. Just oak cost a bit more. Yes that's green oak.
    Heat550
    yooperdave and Backwoods Savage like this.
  12. Backwoods Savage
    Oak slabs can work well with wood stoves too. I've known many folks who burn that year after year and love it. Only problem is getting stove to hold fire all night and that is where some large logs would help out nicely.
  13. LinkedXJ
    LinkedXJ
    Indiana
    I can get those for $10 a bundle here locally from a pallet company.
    Bark included though...
  14. Heat550
    Heat550
    Minnesota
    Oak ? Do you live next to the mill ?
    Heat550
  15. billb3
    I've burned them in a wood stove.
    They were dropped off free and loaded with bark.
    Bark is supposed to have the same BTU as the wood but I never thought so.
    Like pine they were a bit of work, but when you don't have much money and the wood you do have is green ....
    VOLKEVIN and Backwoods Savage like this.
  16. The Wood Wolverine
    When I was a young pup, my father bought quite a few loads of slab wood. We had a mill somewhat close and it was a bargain. All hardwoods and bark on. I remember it seemed to take forever to pack the furnace! He had an oil/wood/coal combo.
  17. FatBoy85
    FatBoy85
    Washington State
    Definitely sounds like it would. Loading a stove like you may be folding boxes in the recycling. Gets them packed but they get pretty thin too.
  18. LinkedXJ
    LinkedXJ
    Indiana
    Oak
    Im about 20 miles from about 8 mills..
    Amish land
  19. panolo
    panolo
    MN
    I have started the year with them. They burn well. I got mine out of Pierz, Mn from Jeremy Lucking. They were 2 years dry so there is no issue with lighting or keeping going. I feel it does seem to burn a little faster than splits or logs.
  20. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Probably too much surface area compared to a similar weight of splits.
