No oil to bar. Stihl Wood Boss 028 AV
Discussion in 'Chainsaws and Power Equipment' started by cootcraig, Apr 5, 2021.
  1. cootcraig
    cootcraig
    E. of Pueblo, Colorado
    Another task for my 028 fix ups. There is no oil getting to the bar. I've been educating myself here and on youtube. The chainsaw starts easily, idles, and revs nicely, but needs more work to cut wood. I do some checking on the lack of bar oil shortly and want to finalize an order with the local Stihl dealer later today.
    Thoughts on how to diagnose the oiling problem will be appreciated.
  2. Chud
    Chud
    NC
    Is it pumping oil? Does it have an adjustment screw to increase oil output?
  3. Canadian border VT
    My guess is worm drive..
  4. PlumbSplitter
    PlumbSplitter
    Bayville NJ
    Oil hole in bar maybe plugged. Is the oil pump pumping??
    BuckthornBonnie likes this.
  5. cootcraig
    cootcraig
    I've got some parts on order including a rim sprocket kit, when they show up I'll check out the oil pump.
  6. cootcraig
    cootcraig
    How would I check? I checked the oil tank, pulled off the bar, cleaned the oil channel, fired up the saw; no oil seen.
  7. Canadian border VT
    Worm drive looks like screw
  8. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Steps-
    Rinse the oil tank with old mixed gas, dump out, then fill with clean bar oil.
    Take off bar/chain and start saw. Warm up a bit and look on clutch side with cover removed for oil coming out. Blip throttle occasionally.
    It should be pretty obvious.
    If no oil, remove clutch drum and you’ll see a plastic gear pressed into the pump. These 1118 (series you have) oilers are ok. I haven’t run into many that are stripped out. Dont order anything until you diagnose the issue. Some of the oil pumps/parts for 1118/1119 are pricey.
  9. The Wood Wolverine
    What he said^^. :yes:
    Canadian border VT and MikeInMa like this.
  10. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
  11. cootcraig
    cootcraig
    The order I put in had bar, chain, rim sprocket kit, and some master switch related things, no pump parts. I'll look at the worm gear when I pull off the spur sprocket.
    "Warm up a bit and look on clutch side with cover removed for oil coming out" did that, no oil.
    farmer steve likes this.
  12. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    K. Clean oil tank w gas, then check again.
  13. cootcraig
    cootcraig
    Will do. thanks.
  14. Nixon
    Nixon
    West Sunbury,Pa .
    34440506-66E2-48D6-8B1A-4E3105DF6003.jpeg If ,you haven’t done so . Take the cover off the oil pump / clutch chamber ,and check the condition of the oil pump drive gears . The 028 doesn’t use the worm gear that most Stihls we are use to do . There are about 3 versions of drive on that saw . So, you’ll be best off visually checking things in there .
  15. farmer steve
    farmer steve
    top of the hill york co. PA.
    Filter in oil tank? Another thing I have done is very light air pressure back toward the tank from the oiler hole.
  16. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Right, it’s a plastic gear and Ive only seen one failure in about ten 028s I’ve been into.
