New wood moisture meter with 4 different settings?
Discussion in 'The Wood Pile' started by KeswickRidge, Oct 31, 2019.
  1. KeswickRidge
    KeswickRidge
    Keswick Ridge, New Brunswick
    So with the new house we bought, there was a cord of wood outside under some trees near the house in a spot that doesn’t get much air flow. It looked like it has been there for a while and the wood had checks on them which makes me think they are well seasoned, but there is also a little fungus and mud that splashed on the pile from rain coming off the metal roof (no rain gutters). I couldn’t figure out if the wood was well seasoned or still wet so I bought a wood moisture meter to find out.
    The problem is that the moisture meter has 4 different settings you can use depending on the type of wood, and I don’t know what kind of wood I have. When I tested it on the same piece of wood with all 4 settings, there was a difference of 10% on setting A vs setting C.
    Do you guys know what the difference would be for each setting? I assume it’s the density of the wood (soft vs hard wood) but in the list for each setting the description is very basic. Like it just says for Cherry use setting “C”but if I look at a wood hardness chart online, North American cherry is rated at 950 (soft) and Bolivian cherry is 3190 (hard)
    anyone have any thoughts or input?
  2. moresnow
    moresnow
    I'd go with C. Just like multiple guess questions back in school:picard:
    Otherwise maybe test a known seasoned split and adjust your setting until it makes sense and stick with it! Orrrrr match it up with someone elses known meter on the same split. Couple of ideas.
  3. KeswickRidge
    KeswickRidge
    Hahaha Setting C gave me the highest reading so I think I’ll go with that and aim for 20% so I know it’s either 20% or lower. I also assume the wood is mostly maple so C made sense
    Chaz, Horkn and moresnow like this.
  4. Horkn
    I'd say go with setting "C" as well.
    I mean, that is unless you know you have kokrodua, afromrosia, or bidinkula.
    :whistle::thumbs:
  5. buZZsaw BRAD
    I think i have the same one and use C most of the time. If im not sure ill use all 4 and kinda average it out. I process only hardwoods.
    Chaz and saewoody like this.
  6. Locust Post
    Eenie, meeni, minee, mo. Catch a tiger by his toe.
    Chaz likes this.
  7. MikeInMa
    A is for ash, apple, alder, aspen
    B is for beech
    C is for cottonwood, cedar
    D is for dogwood
    You need their high-end model for others.
    JUST KIDDING! !!
    The manual doesn't say which setting to use?
    Chaz and Horkn like this.
  8. buZZsaw BRAD
    Chaz, huskihl, Horkn and 2 others like this.
  9. KeswickRidge
    KeswickRidge
    Chaz, buZZsaw BRAD and Horkn like this.
  10. KeswickRidge
    KeswickRidge
    I posted the picture of the manual in my first post. The problem is how broad the definition of the wood is in the manual. Maybe I’m just being too picky ‍♂️
  11. Horkn
    It does. But as I pointed out, most of the species are definitely not your North American tree species.
    My new one has 10 different settings, and a lot of the species mentioned are super foreign. So I went off the 1-10, 10 being the most dense wood and go from there depending on what wood I'm checking MC on. I also verified readings based off of my other MM. It's accurate, and super handy.
    Chaz and buZZsaw BRAD like this.
  12. Horkn
    It's understandable why you'd question that. Teak is super dense. That's on "A", but so is walnut. Well, the Walnut we know here is only a 16 mbtu a cord wood, so it's not dense at all.
    "B" is white poplar and some foreign tree. Well, poplar here in NA is on par BTU and density with the tree species on setting "D", which are softwoods. Setting "c" is ash and elm. Ok, a good mid grade ~20 our so mbtu a cord wood.
    It just makes little sense on the a through d scale. That's all.
    I say since you tried all settings, and c is the most pessimistic, go with that. Now you could double check it with a different meter, or try a burn test too.
    Chaz likes this.
  13. KeswickRidge
    KeswickRidge
    Yeah I think I’ll stick with mostly C/D for hardwoods and A/B for softwoods. I was just surprised at how much a difference there was between settings. I was under the impression that most wood moisture meters don’t even have settings like that. If there was only one setting, how would it accurately measure the wood if it didn’t know if it was a softwood or hardwood?
    Chaz, Horkn and buZZsaw BRAD like this.
  14. huskihl
    huskihl
    I have the same one. I cut down a green water elm and “c” said it was at 55%. I’m gonna roll with it :D:doh:
  15. saewoody
    saewoody
    Central CT
    I had that same one. Gave it to a fellow wood burner at work. C was consistently the setting that always matched my other meter. I have since gotten another meter which is the same brand as my first meter (different brand than the one I gifted), and it too had C as the most consistent reading compared to my first meter.
  16. Horkn
    Easy answer. It wouldn't. In order to be accurate, they need settings depending on the density of the wood. They possibly could self calibrate for different wood density, but on a cheap one, I doubt it. The Ryobi phoneworx is probably the exception at $25, because it uses your phone as a display. So it's got all sorts of wood settings.
    saewoody and Chaz like this.
