New (to me) wood chipper!
Discussion in 'Chainsaws and Power Equipment' started by schlot, Mar 16, 2014.
  1. schlot
    schlot
    NW Iowa
    Tired of looking at my branch pile at my processing site so I picked up a chipper today.
    Owned by two different people. Both of whom must have used it pretty sparingly as none of the paint was worn and I could hardly seen any signs of use or abuse. I think it got dustier in the back of my truck, traveling down the gravel roads than from use.
    Test ran it, fired up great and did a nice job of chipping. All for $100.
    I'm thinking I came out ok on this one.
  2. Well Seasoned
    Nice, good deal!
  3. schlot
    schlot
    NW Iowa
    Thanks...I'm pretty pumped
  4. MasterMech
    Good find! Try to locate some spare knives for it.
    schlot likes this.
  5. savemoney
    I have one I seldom use. It is a PIA to use. Branches get stuck left and right. Takes so much time getting the stuff sized to fit. I think the bigger ones are better. I've seen men tossing in limbs that get sucked right in as soon as the hit the chipper. Mine is some 5 hp model. Says it will do two inch wood, but I have found any thing over a inch binds it up.
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Good deal indeed !! Have fun :)
    schlot likes this.
  7. swags
    swags Moderator
    That's great! How big of branches will fit in it?
  8. Gasifier
    Jealous here. Hi. Good for you. That is a good deal. Hope you get lots of use out of it.
    schlot likes this.
  9. 343amc
    343amc
    Northeast Lower Michigan
    Nice. That's a bit fancier than the Baker chipper I picked up last fall from a relative (mine has a plastic hopper). The unit I have does an OK job with small branches, but chokes a bit on stringy stuff.
  10. schlot
    schlot
    NW Iowa
    Hopefully it will work fine for me. I usually take 2" stuff for stacks, so my branch pile is usually made up of pretty small stuff...hate wasting wood!
  11. schlot
    schlot
    NW Iowa
    Not sure yet....I downloaded the manual just now.
  12. billb3
    Before the engine seized on mine ( not a Baker ) it ate green wood with more ease and less shock and noise than petrified hard as a rock dried up stuff.
    chipper and flails ?
  13. My IS heats my home
    My IS heats my home
    Albany, NH
    The 'wood chipper' reminds me of a movie. Fargo, if I remember right. Don't think you can get any body parts in yours without clogging. :)
    schlot likes this.
  14. chris
    chris
    SE WI
    I have a 5" Bearcat chipper shredder- 20hp, sure beats loading a trailer or the pickup and dragging to recycle center. Yes it will chip 5" dead locust.
    MasterMech and swags like this.
  15. swags
    swags Moderator
    I just burn brush at home, works for me. But would be nice to have a chipper.
  16. MasterMech
    Those Bearcats are excellent units.
  17. chris
    chris
    SE WI
    The powers that be have all kinds of regs on open burning, boils down to when the sun , moon , and stars all align on the 7th planet ect. so its either chip it or drag it
    MasterMech and OhioStihl like this.
  18. OhioStihl
    OhioStihl
    Southern Ohio
    We always stacked up brush in drainage ditches to prevent erosion or left them stacked in piles for rabbit cover. Looking back, I wish we had a chipper and dump the chips on muddy trails. Nice find for $100.
    schlot likes this.
  19. Oliver1655
    Oliver1655
    Central Missouri
    Brother has a 5 hp unit & unless the limbs are real flexible, they are almost impossible to feed. Oak limbs, especially dry, forget it!
    I would like to have a large one like the tree trimmers use but they are way out of my budget range. So, I'll continue using the limbs for wild life habitats or burning depending on the situation.
  20. chris
    chris
    SE WI
    Ya, I got a 8 hp mtd jam-a-matic as well as the Bearcat, Good for leaves but only if they are dust dry, supposed to take up to a 3"branch, lucky if will due 1" green can't hardly give it away. Sorry excuse for a machine. It's the reason I got the bearcat. Bearcat did a nice job on the 40 yards by 10 ft of buckthorn I ripped out couple summers back. Only had to do self surgery a few times - dang thorns.
    MasterMech likes this.
