New to me 361
Discussion in 'Chainsaws and Power Equipment' started by Dok440, Jan 17, 2025.
  1. Dok440
    Dok440
    NorCal
    Over the holiday break I bought a MS361 on marketplace. I have wanted one of these 36x series saws since SawTroll loved them so much on the green forum ten years ago or more. This saw is in pretty good shape. The piston and cylinder look perfect. It needed the oil tubes blown out and I replaced the oil line, filter and sealing ring.
    This is a sweet saw to use. It's not super powerful but handles nice. I ran a 24" bar because that's what I had on hand. I'm thinking a 20" would be about right!
    I need to work on the carb tuning. This thing is hard to hear the four stroking. I think the muffler is a little too aggressive. Anyone run one of these and have suggestions to get a little more out of it?
    For it's first day of work I cut up some blown down tress then dropped some live oaks and cut out some brush.
    20250112_175212064_iOS.jpg 20250116_204721045_iOS.jpg 20250116_204730972_iOS.jpg 20250116_205824901_iOS.jpg 20250116_215234747_iOS.jpg 20250116_233118856_iOS.jpg 20250116_233123567_iOS.jpg
    Ohio, NYH1, Rope and 24 others like this.
  2. Swanman
    Swanman
    NW Montana
    My first real saw was a 361 that I bought new in about 2006. It has been a faithful workhorse since then. I really like a 24” on mine. In 18 years I have replaced the spark plug, the air filter, and the clutch springs. The clutch springs were my fault. I ran it hot trying to get the last of a 30” fir tree cut up to bring home. It was my 1 saw plan until I bought my 500i. IMG_0370.jpeg This was the tree that I smoked the clutch on. It was a much younger me, but I never was a quitter.
  3. buZZsaw BRAD
    I bought my 361 from jo191145 Summer 2020 when my 460 got wounded in action. He bought it new(sort of) and barely used it so it had very low hours on it. Great saw. I ran it once with a 28" bar bucking larger maple (it was my biggest saw at the time), but a 20" is ideal IMO.
    Since acquiring all my bigger saws and getting the 460 fixed it doesn't get used that much. Funny as I found a decent 362c on FBM I'm pondering. Seems I like mtronic saws these days.
    Congrats on the "new" saw and looking forward to seeing it in action.
  4. Dok440
    Dok440
    NorCal
    That's a lot of tree! What are you running today?
    eatonpcat, John D, metalcuttr and 4 others like this.
  5. tamarack
    tamarack
    paulina oregon
    Stihl 361 is a great saw. Those and the husqvarna 262xp are probably the best 60cc saws of all time.
    eatonpcat, John D, metalcuttr and 6 others like this.
  6. Swanman
    Swanman
    NW Montana
    I picked up a 500i in 2020. I still like to run the 361 a bit. It is narrower and a bit lighter. I don’t think my 361 knew that it was only 59 cc. With a sharp chain and the right touch, it is a real workhorse.
  7. Dok440
    Dok440
    NorCal
    I did some brushing on a hillside today. The 24" bar is really too long but the saw worked great. I'm dealing with a combination of manzanita, live oak and buck brush. I basically have to cut my way in and cut my way out. A shorter bar would get hung up a lot less. I would normally run the 346xp but I'm excited about the new saw. I imagine you are using the MS400 for the under 70cc work? Do you use the 241's much?
    eatonpcat, John D, metalcuttr and 2 others like this.
  8. Dok440
    Dok440
    NorCal
    That's a really nice saw. I have looked at the 500's at the Stihl dealer and they are definitely lighter than my 440 and I hear they make more power. I imagine it would be hard going to anything else when you have that hot rod!
    eatonpcat, John D, metalcuttr and 3 others like this.
  9. Swanman
    Swanman
    NW Montana
    It is fun to run. I had them put a 28” light bar on it when I bought it, but I have since put a 32” Stihl lightweight on. For me, the balance and reach are about perfect with that length. The only gripe that I have found is the filtration. The stock filter plugged fast and let in a few fines around the edges. I tried an outerwears prefer. It helped with the plugging. I now have a foam filter from Egan. That is doing a great job of keeping things clean. The Doug fir bark is super dirty and dusty. I know that guys cutting in cleaner wood have less trouble with the stock set up.
  10. Dok440
    Dok440
    NorCal
    I spent three days on the saws brushing one area in the back of our property. I was able to use the 361 and the 562 back-to-back. The 361 feels like my other Stihls so the familiarity is comfortable to me. The Husky is also comfortable to handle, just a tad different. The Husky is smoother with better anti-vibe and noticeably more powerful. Weight-wise I don't feel a lot of difference.
    I was able to ALAP several 20"+ size stumps and the Husky had a much easier time with the 24" bar buried. The 361 did it, but you could tell it was slower in the cut.
    I love both of these saws!
    Here are the results in firewood. About a cord split and two cord in the pile to be split.
    Here is the area cleared. Just brush piles left. The next good burn day I'll use the grapple to bring the brush up to the burn pile.
  11. Skier76
    Skier76
    CT and SoVT
    Nice score Dok!
    metalcuttr, John D, Dok440 and 3 others like this.
  12. Rope
    Rope
    Alaska
    Any wild pigs running around those fine looking trees hills?
  13. Dok440
    Dok440
    NorCal
    Thanks, love this time of year. We have about six months of green and six months of super dry and brown. I have to get my firewood and clearing projects done before June. No pigs, hundreds of turkeys, dozens of deer around here.
  14. Dok440
    Dok440
    NorCal
    I looked at modding the stock muffler but I found I can buy a modded muffler on ebay for cheap. This means if I do have to cut when its dry and fire danger is higher I can swap back to the stock muffler which has a spark arrestor. I switched to a 20" bar and the saw is better balanced. I love the sound and feel of this saw now.
    Skier76, John D, metalcuttr and 9 others like this.
  15. Dok440
    Dok440
    NorCal
    I cut some downed limbs and set a brush pile on fire before the rains hit. The saw was a blast to use! Question for everyone- how do you get a brush pile lit? I used diesel but I think it was too cold. Spent nearly an hour getting it going.
    eatonpcat, John D, Screwloose and 5 others like this.
  16. buZZsaw BRAD
    Maybe warm the diesel up next time?:D
  17. Ohio
    Not Ohio
    I use a propane “weed burner” hooked to a 20lb grill cylinder. That torch is not asking it’s making a fire. I had some diesel from washing parts I also used. Lots of farmers around here use dirty oil from their tractors and that stuff brings the heat.
    Last bonfire I lit I made a fire starter torch. 4 wood splits lashed together with a piece of barbed wire. Set the splits in diesel or kerosene or used oil, if you think ahead and let it set a week it will be good and saturated. I did flip it over once to get both ends soaked. IMG_3727.jpeg
    Final step, jamb a pine split into the bundle, now you have an handle. The torch will burn for quite some time and hot. I also had wood noodles soaked in diesel above where I set it in the bonfire.
    This wood was wet, punky and the outside temperature was in the low 30s and halfway covered in snow.
    eatonpcat, John D, MAF143 and 7 others like this.
  18. Dok440
    Dok440
    NorCal
    Lots of ideas here thank you! I am going to try that torch idea, will put one together to soak this weekend.
  19. Eggshooterist
    Eggshooterist
    Erff
    Used motor oil, torch and a leaf blower
  20. Tiewire
    Tiewire
    Missouri
    Maybe a tire or two also:D:eek:
