New Firepit!
Discussion in 'The Wood Pile' started by Ralphie Boy, Mar 9, 2022.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    So, I bit the bank account and purchased a Solo Bonfire firepit. I love this thing already. I won't miss the bucks I spent on it. There may even be a second one in my future.
    In the picture you can pretty clearly the secondaries lighting off.
  2. MikeyB
    MikeyB
    Long Island NY
    I hear good things about this pit. Congrats.
    I sure do love my S&S Hemisphere pit.
  3. Ralphie Boy
    Ralphie Boy
    An even better look at the secondaries lighting off.
  4. Slocum
    Slocum
    North Central Indiana
  5. Farmchuck
    Farmchuck
    Nepa
    That’s beautiful! How expensive are they if you don’t mind me asking.
  6. Greenstick
    Greenstick
    I've never looked into them. Are there cold air intakes on the outside?
  7. brenndatomu
    No, its not! ;)
    How big is it Ralphie?
  8. buZZsaw BRAD
    Nice new toy there RB. How much? How good does it toast a marshmallow?
    Wont be long now to fire up (no pun intended) the outdoor one here.
  9. Ralphie Boy
    Ralphie Boy
    It's double wall construction with intake holes around the bottom. The wood sits on a perforated platform that is fed air from the intake holes around the bottom. There are outlet holes around the inside top that produce the secondaries.
    When you add wood, after it reaches operating temps, the smoke normaly produced in a firepit is converted to secondary flames that extend into the center from all around the holes at the top. It's quite a show.
  10. Ralphie Boy
    Ralphie Boy
    It's the mid-sized model. The inside diameter is 17" and the outside is 19". I'll have to make some 10" and 12" wood to go along with the 16" stuff I usually use. And smaller splits.
  11. Camber
    Camber
    Montana
    reminds me of one of these. I want to build one. won't be as nice as yours
  12. Ralphie Boy
    Ralphie Boy
    I bought it from Solo in a "bundle deal" for $289.00 plus tax, shipping was free. The deal included a base so it can be used on a deck and a zip up cover to keep in when not in use. Something like $307 after tax.
  13. Ralphie Boy
    Ralphie Boy
    Maybe not but it ain't gonna cost ya a bunch of money either. :D :salute:
  14. Camber
    Camber
    Montana
    :salute:. No sir, but I figure it will take me four hours or so. I've been putting it off for quite some time now. I have barrels sitting under snow right now.
  15. buZZsaw BRAD
    Havent they used washing machine drums for firepits like this? Work on the same principle?
  16. Ralphie Boy
    Ralphie Boy
    Seems like all you would need to do is drill holes in the outer, larger barrel bottom edge then drill holes in the bottom and around the the top of a smaller barrel, then put the smaller inside the larger, outer barrel.
    Pictures when you get it built! Good luck! :salute:
  17. Ralphie Boy
    Ralphie Boy
    I've seen firepits made from washer and drier drumbs but never as a 'secondary burn' type firepit. After using this I don't see how they would work. Seems like the are too many holes in the burn drum and no outer drum.
  18. The Wood Wolverine
    Wow! That is truly awesome. I’d definitely want to be out using it more than just a normal old pit. Pics are great too. Thanks for sharing Ralphie Boy
  19. Eric VW
    Yep, that’s all ours is. Reclaimed stainless washing machine drum.
    But I kept it stock- the single wall of the drum is all there is- which allows heat to radiate and warm from the ankles up.
    Ralphie Boy - during your initial burns, have you noticed your lower extremities getting warmed well? Too well?
    My concern there would be the double wall setup- because ultimately air insulates… and if I’m sitting around a fire pit, I don’t like my lower legs getting cold while my face is practically melting.
    Make sense?
  20. Eric VW
    Our single wall drum in fact produces secondaries.
