New BK, KEJ1107, Cat, blower, glass door
Discussion in 'Modern EPA Stoves and Fireplaces' started by bogydave, Oct 24, 2018.
  1. bogydave
    Been burning, got it hot a couple times, got the “New” burned off it.
    3/4 loads , 36 hour burns on Low. (40°s, rain, wind)
    Glass in Door is black from burning on low.
    Few changes from old one, mostly lipstick.
    The guys that moved the old one out & new one in said new one is a lot lighter.
    (left 1/2 cord birch in the old one :D )
    Got descent deal & spare cat at 1/2 price.
    Got a bunch of wood in basement, over 4 cord. (2017/18 wood) (4+ yrs CSS'd - Oct 2014)
  2. Maina
    Maina
    Maine
    Very nice! 36 hour burns are incredible. And having your winters wood right by the stove is just plain smart.:thumbs:
    So why is the new stove so much lighter, other than that birch?:rofl: :lol:
  3. Eric VW
    That’s a thing of beauty right there, bogydave :salute:
  4. yooperdave
    Nice. What was wrong with the old one? How many years did you have the old one?
  5. lukem
    Never seen a stovepipe wrapped like that....what's the story there?
  6. bogydave
    Thinner steel is my guess
    Backwoods Savage, Maina and mat60 like this.
  7. lukem
    Could be less firebrick?
  8. bogydave
  9. bogydave
    Long flu, basement instsll, most is outside.
    cool air heavy,even with double wall. Even small leaks cool the pipe , & I get a down draft when stove is cool.
    Mostly this time of the year when burning on low , not keeping flu hot & a good fire going.
  10. BDF
    BDF
    Congrats- nice stove and it sounds like a great deal. Always wanted to try on a Blaze King King but of course taking a stove for a 'test burn' is not an easy or inexpensive thing.
    Brian
  11. yooperdave
    savemoney and Maina like this.
  12. Maina
    Maina
    Maine
    Let’s hope it’s all in the right places! Do you see any changes that might prevent the issue you had before?
  13. bogydave
    No.
    Not sure what I could do either.
    Small piece of firebrick stuck in there?
    Backwoods Savage, Maina and savemoney like this.
  14. edyit
    edyit
    Wilmington NY
    would fire brick really help if you're running it low and slow? its a smoldering mess with the cat cleaning it up and making the heat at that point right?
    Backwoods Savage and Maina like this.
  15. lukem
    If anything you'd want to add some insulation to the outside of the stove to keep that area warm so creosote doesn't condense on the inside. Little rock wool stuff inside the blower cover?
  16. bogydave
    Start new burn cycle fire
    Sean, Backwoods Savage, mat60 and 5 others like this.
  17. Highbeam
    Highbeam
    Even wrapped the handle. I suppose that is to prevent charring the wood?
    So did you need to pay for the new bk? Fellow low and slow softwood burner would like to know!
    Maina and papadave like this.
  18. BDF
    BDF
    Insulating the firebox actually allows a cat. stove to run low and slow while still burning clean. Non- insulated fireboxes take too much heat out of the actual fuel bed so the fire has to be turned up quite a bit higher or it goes out. Plus restricting the heat in the firebox really helps to raise the temps. at the top of the firebox and that keeps the cat. lit and working at far lower settings than any non- insulated type of stove can manage.
    Not all that important for people who always run their stoves 'hot 'n fast' but a requirement for an efficient, consistent slow- burn.
    Brian
  19. bogydave
    Yea
    BK said 9 years was out of warranty.
    Backwoods Savage, Maina and Highbeam like this.
  20. Highbeam
    Highbeam
    Thank you. I hope for more than 9 years on mine!
