Need advice on pressure washer
Discussion in 'Chainsaws and Power Equipment' started by Backwoods Savage, May 13, 2017.
  1. Backwoods Savage
    As I age, I grow more and more to hate recoil starters. However, I did find a good buy on a new one that a friend had purchased 2 or 3 years ago so told him I'd take it. However, no money has changed hands.
    It is a 3000 psi with 2.7 gpm capacity. That, I thought would be an ideal size but I am not totally certain what psi I really need.
    Use will be for washing siding on house and steel barn. Also washing car, tractor, etc.
    Now I'm uncertain as I started looking at electric washers. Most seem very expensive compared to gas engines. Also most electric seem to be around the 2000 psi and less than 2 gpm output. Would this be enough?
    One that caught my eye is a Ryobi with Subaru 3100 psi, 2.4 gpm with electric starter. At $389 it is not cheap but doesn't seem that bad either.
    Suggestions?
    Maina, stuckinthemuck, Hammy and 3 others like this.
  2. brenndatomu
    2K PSI and 2GPM will do what you want to do with it. Now if you want to remove HEAVY mud from the quad or tractor frequently you will like something bigger even more. I have a electric one with something like 1800 PSI and 1.6 or 1.8 GPM...it does fine. One thing that makes any washer seem "bigger" is a "turbo nozzle". It is a nozzle with a straight thin concentrated stream that spins around in a circle, sounds silly but they really make a big difference depending on what you are trying to accomplish.
    FYI, a Honda powered washer normally will start very easily even with recoil...but if you don't mind the xtra cost and battery maintenance of electric start, then that will be the way you will want to go.
    Maina, 94BULLITT, chipper1 and 6 others like this.
  3. Armbru84
    Armbru84
    Sparta, Michigan
    I have an electric one as well and it does great for me. I wash my truck, loader, and other vehicles with it. Higher psi is great if your in the mud a lot and I have noticed you have some at your place! It's not the heavy thick stuff though.
    :tractor:
    Maina, chipper1, Hammy and 5 others like this.
  4. Backwoods Savage
    Yes, we did have mud this year, but usually it is not a big problem. So perhaps 2000 psi would be okay? How about the amount of flow? 2 gpm or less?
    Maina, chipper1, Hammy and 2 others like this.
  5. Armbru84
    Armbru84
    Sparta, Michigan
    I am not at home to check...but based on the little bit of searching I did on my phone, mine must be less than 2k psi and under 2 gpm. I think if you stayed around those numbers it would be fine. As brenndatomu said, nozzle makes all the difference!
    Maina, chipper1, Hammy and 4 others like this.
  6. HDRock
    I think mine is like 2500 psi , honda engine , It will take paint off if you hold it to close
  7. HDRock
    What's the best turbo nozzle ?
    Maina, chipper1, Hammy and 3 others like this.
  8. ironpony
    ironpony
    Mid Ohio
    An electric around 2000 psi 1.8 gpm will do everything you want, as stated above the turbo nozzle is the deal. A turbo nozzle is a single stream which maintains the 2000 psi single stream but oscillates to cover a larger area, if you go to a fan to cover the same area you loose the impact stream which is broken down into little droplets.
  9. ironpony
    ironpony
    Mid Ohio
    It is hard to say the performance is going to greatly vary with pressure, also consumer nozzles are no where near the quality of a commercial nozzle, when I was involved in water blast engineering we were paying thousands for high quality nozzles.
    chipper1, Hammy, brenndatomu and 2 others like this.
  10. Eric VW
    I think the advice shared is spot on, but Dennis, if you for any reason ever needed to (for whatever reason) was something far away from the house, electric would be out- that being said, my 15 year old Kärcher electric is ok for us. The Honda engine on anything above 2K psi is an easy starting, quiet machine.
    brenndatomu's suggestion of a "turbo" tip is dead nuts right- they're great for homeowner tasks!
  11. HDRock
    I remember a while back MasterMech mentioning a turbo tip on his unit.
    I don't have a turbo tip on my unit:smoke:
  12. HDRock
    Dennis it seems to me if you don't get an electric start you will be unhappy
  13. wildwest
    Wyoming high plains
    :thumbs: I'm up for a turbo tip, or atleast try one....
  14. wildwest
    Wyoming high plains
    x2
    chipper1, Hammy and Backwoods Savage like this.
  15. MasterMech
    Flow will trump pressure for most of what you want to do. 2000 psi and 2 gpm will do what you need, but will be fairly slow at it compared to the bigger options. That Ryobi unit at 3100/2.7 would probably be an excellent choice. And if you want to clean hard surfaces like concrete, definitely pick up a turbo nozzle for it. The $30 units in HD and the like will do fine.
    The reason dedicated electric units that compare to a gas powered unit are so expensive is that they likely have an industrial duty pump on it as few homeowners have the proper electrical hookups to run such powerful motors.
  16. TurboDiesel
    Ill agree with the others here. My Honda Karcher 2000 psi ? Does just fine. You can usually find them around $300.
    Be very careful around the quad and tractor, it will take the stickers right off.
    And the 0 tip will cut the clear coat off your car... luckily I found this out while trying to get bugs off my work van:bug:
  17. Babaganoosh
    Babaganoosh
    Jersey Shore
    It's all about the GPM and a good nozzle. Commercial units don't have a much higher psi rating. They pump a lot more water thru though.
  18. brenndatomu
    You will want to buy the turbo nozzle specifically for the machine that you buy (if it doesn't come with it, many do) as they are matched to the PSI and GPM of the washer for optimum performance.
    PSI is important, but so is GPM...maybe even more so. It is always amazing to me how well 80 PSI and a couple hundred GPM (firehose) will clean things up and wash things away!
  19. Marshel54
    Marshel54
    I like you am getting a little age on me. I don't have much patients with an engine that doesn't start easy.
    I had a gas powered Troy-Bilt that I got free with the purchase of my Zero Turn. It sat in the shop for a year or 2. My son-in-law borrowed it and then my son used it.
    I was refinishing my deck last summer. It fired once and never fired again. After a couple of hours tinkering with it, I threw up my hands and went to Lowes and bought an electric.
    I got a 2000PSI Greenworks for under $200. I believe around $175. It works great and would probably meet your needs. It did come with a Turbo nozzle. It would have a little trouble stripping paint off a building but it works for everything I need to do.
  20. HDRock
    :rofl: :lol::thumbs:
    chipper1 and wildwest like this.
