Nc 30 get ready.............
Discussion in 'Modern EPA Stoves and Fireplaces' started by rottiman, Sep 13, 2015.
  1. rottiman
    The weather outside is el stinko so decided to get the final servicing done on the 30. Had given it a good cleaning and vaccuming in the spring. After 3 burn seasons of 24/7, the gasket on the door was getting tired. The door got a good cleaning and installed a new door gasket and glass gasket. Now officially ready for burn season............................:thumbs:
  2. wildwest
    Wyoming high plains
    :thumbs:
    I am doing a deep clean on the pellet stove tomorrow, :confused:
    papadave and rottiman like this.
  3. HammerheadC4
    HammerheadC4
    Eastford CT
    I guess it's that time......I was working on the Ole Smoke Dragon today.
    Was talking with the wife about a NC 30.
  4. Norky
    Norky
    How are the baffle boards holding up after 3 seasons? I'm thinking about getting an extra set of them, just in case.
  5. bushpilot
    bushpilot
    Eastern Washington
    I'm doing the same, shooting for the spring sales. She asked me why I thought we needed a new stove, when the old one heats so well. I said it will burn less wood, little response. And smoke less - now THAT she is keen on.
    Greg
  6. rottiman
    I got 2 years out of the first set. Will probably need another set next year.
    Norky and Chvymn99 like this.
  7. DaveGunter
    DaveGunter
    I got two years out of the original boards also.
    I bought replacement fiberboard here instead of from Englander.
    Ceramic Fiber Board
    Item bt12t12c
    You have to cut it yourself and I think you can get three boards out of that sheet, so you end up with an extra, and you can cut the boards to fit tightly to avoid the gap that the factory boards leave. Shipping is crazy, but it still ends up cheaper. The replacement boards are wearing fine.
    rottiman, Chvymn99 and Norky like this.
  8. Norky
    Norky
    Thanks, I'll have to get one soon. Mine look like they easily have another season on them, but there's always a chance I'll whack one of them and break it with the rake or something.
  9. papadave
    Nice find Dave. Bookmarked.
    Will a normal utility knife make the cut?
    I've only run the 30 for about 1.5 wrs and the boards are fine, other than a few small nicks early in the learning curve.:D
  10. Norky
    Norky
    One thing I want to do to the thirty before I start using it is remove the ash plug, cover the hole and replace it with a firebrick. I don't use the ash pan and the plug just gets in the way when I rake or shovel.
    HDRock and Chvymn99 like this.
  11. chris
    chris
    SE WI
    Just grind off the steel loop no need for any replacement brick. 4 years on the original boards, they are fine yet although i do have a least one broken brick in the back wall.
    Norky and papadave like this.
  12. papadave
    Good call, Chris.
    I use the pan sometimes............
  13. Norky
    Norky
    I wanted to leave it as is, in case I ever did want to use it, but I guess I could always weld a ring back onto it. Definitely the easiest solution. Shouldn't take more than about 20 minutes with a sawzall and angle grinder.
    On second thought, the plug is cast so it probably wouldn't hold a weld very well, but still probably the best solution.
  14. papadave
    I don't really find the plug to be much of a nuisance, to be honest.
    I just checked ESW site to see if they offer a replacement plug......not on the site.
  15. DaveGunter
    DaveGunter
    Yep, utility knife, easy cut.
    My boards would have lasted longer than two years if I hadnta dropped one while cleaning:picard:
    Chvymn99 and papadave like this.
  16. chris
    chris
    SE WI
    loop really isn't that much trouble to go around with shovel, Course I am not an ultra neat freak as far as getting every last spec of ash out, Plus unit works better with a small layer of ash on bottom ( also stated as such in manual- but who reads those anyway- against the man card code I believe)
    rottiman and papadave like this.
  17. papadave
    Well, full disclosure.....I broke a small piece of one corner off of one of the boards last year when I was cleaning.:picard:
    I leave some ash in too, but the stove runs well no matter what.
    rottiman likes this.
  18. Norky
    Norky
    My rake gets caught on the plug ring a lot. I usually clean all of the ashes out of the stove too and the plug gets in the way of that.
    I have a small corner missing off one of my boards, don't remember how it happened. I just keep that corner up front and it's not big deal.
    papadave likes this.
  19. papadave
    You ought to know where it is by now.:p:picard:
  20. rottiman
    Zip wheel on a angle grinder made short order of the loop. Never use the ash dump anyway.
    Chvymn99, papadave and Norky like this.
