Napoleon NZ 3000
Discussion in 'Modern EPA Stoves and Fireplaces' started by NWS, Apr 5, 2015.
  1. NWS
    NWS
    craryville, ny
    Hi All
    Great to see all the posts about this fireplace and have learned lots; I have installed this unit and burn seasoned hickory, elm, and oak. I have not experienced any draft problems or black soot on glass. My burn time on low air is in the 6 0r 7 hour compared to my vermont castings resolute that is more like 8 hours.
    I want to install the secondary heating system off the top of the fireplace and was wondering about others experience. The book calls out for an 8" insulated pipe but have seen Scotty (the master of all installs) step it down to looks like 6" and it does not look insulated. I would like to go to 6" but think insulation is a good idea to prevent heat loss.
    Any folks have experience with this?
    Thanks
    Nelson
    wildwest and fox9988 like this.
  2. fox9988
    fox9988
    NW Arkansas 72717
    Scotty Overkill and wildwest like this.
  3. wildwest
    Wyoming high plains
    Nice to meet you :)
  4. LongShot
    LongShot
    New Mexico -Jemez Mountains
    Welcome NWS. You have made it to the right place. :thumbs:
    wildwest likes this.
  5. fox9988
    fox9988
    NW Arkansas 72717
  6. Scotty Overkill
    Yes I'm here.......
    I'm getting ready to finish compiling my last pictures and putting them in my NZ thread.....finally got the laptop screen replaced, so now I can access those pics again....
  7. Scotty Overkill
    As for stepping down the heat runs, that's what I did. But I'd recommend not insulating the pipes for at least a little ways from the stove unless you use a fireproof, non-combustible unfaced insulation like Kaowool or Roxul. Those heat runs get quite hot near the firebox.
