My son learned some new words today
Discussion in 'Chainsaws and Power Equipment' started by Pricey106, Nov 14, 2020.
  1. Pricey106
    Pricey106
    Northeast PA
    I was putting off maintenance on the splitter for the past month, and had to get it done. We changed the motor oil, cleaned the air filter, then went onto to changing the hydraulic fluid. I drained all the 3 year old fluid, then went to change the filter. I could not get a purchase on it with a filter wrench, or strap wrench. I sprayed it with carb cleaner to remove any grease and wiped clean. I used sand paper in between to create more grip, no go. I proceeded to start cursing it pretty good. Probably nothing my 15 year old hasn't heard before. I did use a new one when knuckles got busted the last time the strap wrench slipped. I resorted to using a 6 inch C-clamp. After messing with that for 15 minutes, I finally broke it loose. Anybody else have a problem with hydro filters?
    blacktail, mat60, brenndatomu and 7 others like this.
  2. Warner
    Warner
    People alway over tighten oil filters. Used to work with a guy we called mongo. Put drain plugs in with a breaker bar and twisted the filter in with all he had. All of my filter strap style wrenches are bent from trying to get filters he put on off. He did not understand that too tight is a thing.
  3. Backwoods Savage
    I never tighten them as much as most recommend and this does save using some of those words! When we bought our tractor though, I learned the manufacturer takes tightening to a whole new level!
  4. Warner
    Warner
    Yes the first filter from the factory is always super tight. We had a few cars towed in when the new owner mangled the filter trying to get it off. Very unhappy people.
    Pricey106, mat60, brenndatomu and 5 others like this.
  5. Backwoods Savage
    Amen
    Pricey106, mat60, brenndatomu and 4 others like this.
  6. Maina
    Maina
    Maine
    A lot of filters say how much to turn after the gasket makes contact but few people read directions. Over tightening filters seems to be a national sport imho.
    Pricey106, Spencer, mat60 and 4 others like this.
  7. Mag Craft
    Mag Craft
    South East Wyoming
    Never met a filter I could not get off. I have had some tight ones before. One time a hammered a long screw driver through the filter and used that to get it to turn. It made a mess but I did get it off.
    Usually a good filter wrench will do the job. I also have a special pair of pliers that are made for removing filters. But over tightened filters are a pain in the but without a doubt.
  8. Ron T
    Ron T
    Northeast Ohio....Bowdil
    I've had to use the screwdriver trick before.
    Mag Craft, Pricey106, Spencer and 4 others like this.
  9. Kimberly
    Kimberly
    The Kangaroo State
    I did that once. I had no choice; that sucker was on there but good.
  10. amateur cutter
    We get a lot of those in the shop, speedy lube did the last oil change.:picard:Correct torque for most filters is 3/4 turn past gasket/O ring contact, not 3-4 turns. Many filters are in tight spots that negate good leverage, it gets to be a pita sometimes.
  11. Will C
    Will C
    New York
    I turn filters as tight as I can with my hand. Works for me, never had one leak.
    Mag Craft, Pricey106, mat60 and 2 others like this.
  12. brenndatomu
    I shared here recently on another thread of a similar topic (or at least a derail :emb:) about a filter my buddy couldn't get off of his newly re-built Chevy 350 (and he installed it too!) tried all the usual tricks and nothing worked, was finally down to nothing left but the threaded flange and Oring surface...that FINALLY came off with a hammer and chisel! :hair:
  13. TurboDiesel
    Back in my teens i put one on too tight. Used the screwdriver trick and almost tore it in half.
    I learned...
  14. brenndatomu
    What did you learn...Tim strong like bull!? ;) :rofl: :lol:
  15. TurboDiesel
    Tim not filter
    Tim not put filter on so tite.
  16. sirbuildalot
    sirbuildalot
    Mass
    I’m usually able to get filters off by hand. It’s the small spaces I can’t physically fit my hand in that I hate.
    Pricey106, Spencer and brenndatomu like this.
