My first IBC tote
Discussion in 'The Wood Pile' started by grandgourmand, Feb 23, 2022.
  1. grandgourmand
    grandgourmand
    Ontario
    Decided to give IBC totes a go. Got 6 of them in total. Here’s the first one prepped. Definitely see the appeal but figuring what to do with the bladder….:hair:
  2. Canadian border VT
    Cut it in half at a 45* angle and put a roof on cage.
  3. grandgourmand
    grandgourmand
    Ontario
    Yeah thought of that. But it’s pretty windy where I’m planning on putting them.
  4. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I have a sheet metal screw through the bladder and into the frame rail on each corner. They catch plenty of wind and haven’t come off yet in going on 3 years
  5. Slocum
    Slocum
    North Central Indiana
    I use bailing twine, I use a slip knot and have no problems. 4DBE5FAC-296D-4652-A650-A790EA9C5258.jpeg
  6. buZZsaw BRAD
    Zip tie the chit out of it??? Never have used one and just an idea.
  7. Rickyblazin
    Rickyblazin
    Pottstown PA
    My brothers had to have these ibc totes refused to stack wood anyother way so we went out brought back 20 of them on his truck and trailer double stacked .ofcourse than he starts up about the bladders “it took me too many hours to cut them out i dont have time to be doin this how is this lucrative theres yellow paint in them wahhh wahhh …” drove me absolutely nuts hearing him bitch and moan about it but they are nice to have once you figure out how to get rid of the bladders
  8. Ohio dave
    Ohio dave
    Akron, OH
    I gave 12 bladders to a guy that said was stacking them 2 or 3 high filling with dirt so they would work as a backstop for target shooting.
  9. buzz-saw
    buzz-saw
    Ct.
    Nice looking machine in the background.
  10. Eckie
    Eckie
    Ah yes, the orange bailing twine...the kind that will be here with the cockroaches at the end of time.....
    On the farm, if you can't fix it with a hammer, duck tape or that orange bailing twine, you've got a real problem....
  11. WinonaRail
    WinonaRail
    Indiana, US
    I use the bladders for roofs. I don't like to fasten them permanently as I prefer to remove them for loading/unloading. The sheet metal screws are a good choice. I've also cut the bladders straight across about 8"-10" from the top or bottom. I zip tie one side, acts like a hinge. Throw some scraps on top and it won't go anywhere.
  12. WeldrDave
    Drill 3/8" holes around the bottom, about 1" up from the base of the cut area and bungy cord them down. Easy off and easy back on, no knots from tying and no screws. All Great Ideas though! :yes:
  13. Yawner
    Yawner
    Louisiana
    I was going to say that I have seen somebody that cut them square instead of making two triangle shapes, maybe it was you, and I like the Square better just from the look of it.
  14. WinonaRail
    WinonaRail
    Indiana, US
    The only problem I've notice is that rain and snow tend to accumulate when used flat but the whole thing has a more streamlined look and still works pretty well.
  15. sirbuildalot
    sirbuildalot
    Mass
    There are many uses for both the cages and the bladders. Unfortunately cheaper or free cages often include dirty bladders that are tough to clean out. The food grade ones are usually $$$
  16. LordOfTheFlies
    LordOfTheFlies
    NY
    Nice! How much did you pay for them? I paid $25 each for mine. 4 with the bladders, 2 without.
  17. brenndatomu
    The other issue with cutting square is there is no overhang...it still fits inside the cage...when you cut on a 45* that effectively makes it longer on the bottom then, so it allows you to expand it out over the cage so there's no dripping on the wood (or a lot less anyways)
  18. sirbuildalot
    sirbuildalot
    Mass
    It also gives more air flow around the wood, especially if you drill a few decent sized holes in the sidewalls of the triangle top.
  19. LordOfTheFlies
    LordOfTheFlies
    NY
    I use my bladders and drill holes in them and store kindling.
    I cut the tops horizontally so it makes a removable lid. I also make a small "door". In hindsight I should have made the "door" the width of the opening. Make it a bit easier to my fit into.
    I have 5 of them full of kindling (one used up this winter)
  20. grandgourmand
    grandgourmand
    Ontario
    I paid $50 Canadian. So about $40 USd. Can’t get them for $25.
