Mt. Vernon AE thermocoupler
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by tsmith, Oct 14, 2015.
  1. tsmith
    tsmith
    Kutztown, PA
    So I tried to fire up my quad last night and I got the bad TC fire pot warning. When I removed the TC wire from the motherboard, I found that the 2 wires were loose in the connector and pulled right out. I tested the TC and got 22 mv. I then pushed the ends of the wire back into the connector and tested again by touching the connector ends and I got 22 mv. When I connect it back to the motherboard and try to start it I immediately get the bad TC warning. So can I assume that because the wires pulled out of the connector that it is not connecting right to the board or could I have other issues? I figure I need to purchase a new TC, But I am not certain because it does read millivolts properly. The stove is 7 years old and the TC was never replaced.
    wildwest and ivanhoe like this.
  2. smoke show
    smoke show
    Pittsfield, Wi
    Does the fire start then go out?
  3. tsmith
    tsmith
    Kutztown, PA
    No I can't get it to do anything, When I try to start it up, the bad TC fire pot warning comes up and nothing happens. I can't even push the retry button and get it to reset.
  4. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    BAD TC FIREPOT
    While this message may indicate that the firepot thermocouple may need
    to be replaced, more often it displays if its wire connection to
    the control board has become loose. If the stove was recently
    cleaned or if any of the wires may have been recently disrupted,
    first check to make sure all connections are secure.
    kappel15, wildwest, imacman and 2 others like this.
  5. tsmith
    tsmith
    Kutztown, PA
    I got it working, I Had to push the female pin connectors tighter together to make a better connection. Thanks for the help. I have to give credit to Kap, he was talking to me on the other forum.
    wildwest, imacman, slvrblkk and 2 others like this.
  6. smoke show
    smoke show
    Pittsfield, Wi
    Send kap over here. :zip: I always enjoyed his posts on IBC.
  7. Dpopps
    Dpopps
    MI
    kap is a great guy.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    I had a couple questions about the door glass on my new Quad and was very helpful. Even had to check on something and followed up with it.
    wildwest, imacman and smoke show like this.
  9. smoke show
    smoke show
    Pittsfield, Wi
    He'd be a great addition here. :zip:
    wildwest, imacman and slvrblkk like this.
  10. tsmith
    tsmith
    Kutztown, PA
    I believe he has been here, his name shows up on the members list when I did a search for Kappel15, He wasn't here for awhile but apparently knows about the site. I just found out about this site myself by dumb luck. I have been on hearth for a long time. Good to see you all here again.
  11. jtakeman
    Good to see you too tsmith! Glad you found us and welcome aboard!!
    slvrblkk and wildwest like this.
  12. smoke show
    smoke show
    Pittsfield, Wi
    Troy?
    wildwest likes this.
  13. imacman
    imacman
    Denver, NC
    His last time on the site was Feb. '15
  14. imacman
    imacman
    Denver, NC
    Welcome to the "friendly forum"....good to have you here.
    Russell, wildwest and slvrblkk like this.
  15. Dpopps
    Dpopps
    MI
    I also stumbled over a few months back. If things are more busy maybe kappel15 would be around more?
  16. DexterDay
    DexterDay Administrator
    Northeast Oh
    Glad you got the stove going and welcome to FHC!
    kappel15 hope you come see us
    With the addition of www.pelletpigs.com we should have more traffic this year. That link goes directly to our main forum page. Should help us with searches as well.
    wildwest, smoke show and imacman like this.
  17. tsmith
    tsmith
    Kutztown, PA
    Hey smoke show, yea my name is Troy, do I know you?
    wildwest, DexterDay and smoke show like this.
  18. smoke show
    smoke show
    Pittsfield, Wi
    Back in the day... I'm not allowed there anymore. Surprised I remembered, that was a lot of beers ago.
  19. wildwest
    Wyoming high plains
    What is this in woman speak? Makes ignitors turn on and off?
    1. A thermocouple is a device consisting of two dissimilar conductors or semiconductors that contact each other at one or more points. A thermocouple produces a voltage when the temperature of one of the contact points differs from the temperature of another, in a process known as the thermoelectric effect.
      Thermocouple - Wikipedia, the free encyclopedia
      Wikipedia
    Russell and imacman like this.
  20. smoke show
    smoke show
    Pittsfield, Wi
    fancy schmancy proof of fire switch.
    Russell, slvrblkk, imacman and 2 others like this.
