MS461 air filter question
Discussion in 'Chainsaws and Power Equipment' started by Woodrat1276, Feb 2, 2015.
  1. Woodrat1276
    Woodrat1276
    Ky
    Been doing a little research on saws. I have had a interest in the ms461. I have read that the air filter getting dirty quicker is a problem. Obviously thats something to pay atten to on any saw. However is this a problem that im going to have to check each time I refuel and oil.
    I typically run my saws during the course of the day then when work is done go back blow them off clean them up have them ready for the next days work.
    Basically I am asking the ones who own them are you having to clean the filter in the field during the course of 6-8 hrs cutting up firewood
    Ralphie Boy likes this.
  2. Woodrat1276
    Woodrat1276
    Ky
    Stupid auto correct grrrrr ms 461.
  3. NewToStihl
    NewToStihl
    Central Indiana
    I used to have one and although most of my cutting was green wood, I didn't have a problem with it clogging quicker than normal. I use Outerwears prefilters which helps quite a bit too.
    MasterMech, foragefarmer and mdavlee like this.
  4. mdavlee
    mdavlee
    Can you run a max flow on them? I never paid that much,attention to them.
  5. Gunn
    Gunn
    Plover, Wi
    I carry a small brush and brush out the air filter when I refuel. It takes an extra 30 seconds to brush the filter off.
    angelo c, $ooline and Woodrat1276 like this.
  6. JustWood
    JustWood Guest
    I do too. Easiest and quickest PM you can do to a saw.
    $ooline and Gunn like this.
  7. NewToStihl
    NewToStihl
    Central Indiana
    I would assume so - has the same filter setup as the 460.
    $ooline and mdavlee like this.
  8. $ooline
    $ooline
    WI
    Agree with others that these are quicker to plug. Nothing like a prefiltered 261/261c that I used to run. I like the idea of carrying a brush...I've been knocking the filter against the bumper of my truck every couple tanks. The big stuff falls right out.
    mdavlee likes this.
  9. mdavlee
    mdavlee
    I couldn't remember if it had the 1/4 turn filter know like the 661 or not.
  10. $ooline
    $ooline
    WI
    Anyone running baileys NWP filter?
  11. NewToStihl
    NewToStihl
    Central Indiana
    It's possible they updated it like I believe they did with the 362, but the early one I had used the standard HD filter.
  12. mdavlee
    mdavlee
    I thought they did have it where you could take the cover off and run it without the cover.
  13. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I have a new 462
    rat1276, post: 257963, member: 2242"]Been doing a little research on saws. I have had a interest in the ms461. I have read that the air filter getting dirty quicker is a problem. Obviously thats something to pay atten to on any saw. However is this a problem that im going to have to check each time I refuel and oil.
    Basically I am asking the ones who own them are you having to clean the filter in the field during the course of 6-8 hrs cutting up firewood[/QUOTE]
    I have a nrw
    I have a new 461, only a few weeks old, and I've only used it a couple of times, once for about 4 hours. I was aware of the air filtration concerns before I bought it so I checked the filter after each hour of operation just for curiosity. I found noting unusual with the filter. I was cutting and bucking some ash (posted pictures earlier) so results could vary with wood types and condition of the wood as well as humidity. I ask the Stihl dealer about a pre-filter like the one on my 660 and my former 441 but they said they didn't make one for the 461. I don't know why the band for the 66o wouldn't work because the filter appears to be the same. The pre-filter band on the 441 looks the same as well.
    You are right up the street from me so If you'd like to try my 461 before you buy on just let me know. :drunk: I added duel dogs and a roller catcher to mine.
  14. wishlist
    wishlist Guest
    I have a 460 that I bought new 3 or 4 years ago. At that time I remember the dealer swapping out air filters for me to the hd2 or something along that line?
    I've cut a bunch of wood with it and usually clean it every other tank . I'll admit I have missed it a time or 2 and just the other day I was cutting and the saw wouldn't idle?,Hmmmmmm, I do use premium ethanol free 100% gas and this was really odd? Shut it down, cleaned dirty air filter and she ran like new again!
    Drvn4wood and $ooline like this.
  15. Woodrat1276
    Woodrat1276
    Ky
    Ralphie what dealer you been using out of curiosity
  16. Ralphie Boy
    Ralphie Boy
    Kubota of Florence and Ideal Farm Supply in Walton. Once I used Crescent Springs Hardware, there is a story there I'll have to tell you about off line sometime.
  17. $ooline
    $ooline
    WI
    Are you in the U.P. Ralph?
  18. $ooline
    $ooline
    WI
    Never ran a 460, but you can cut alot of wood on 2 tanks with a sharp chain on a stock 461...imo it really ain't much trouble to clean these filters every other tank, but I admit it would be real nice to have that 441c air filtration system if it was anything like a 261c.:smoke:
  19. Woodrat1276
    Woodrat1276
    Ky
    I usually go to idea farm supply myself for some things and I really like cottinghams in alexandria too they a pretty good place
  20. $ooline
    $ooline
    WI
    Looked at your profile here...not even close :rofl: :lol:
    Drvn4wood and Ralphie Boy like this.
